Re: Hemi Transmission Coolers
[Re: sogtx]
#64609
12/16/12 04:05 AM
12/16/12 04:05 AM
Posts: 373 sandwich IL
sublimehemi
sandwich IL
bump...i know this thread is old but does anybody now where you can get a new one cheaper?
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
[Re: sublimehemi]
#64610
12/16/12 04:42 AM
12/16/12 04:42 AM
Posts: 5,123 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
If you are looking for a B body cooler what year. Brackets are a little different between years and if 1971 they all take the E Body style cooler. I can see if the person on moparts is still doing the coolers.
1971 HEMI E BODY REGISTRY
[Re: hemicar1971]
#64611
12/16/12 07:16 PM
12/16/12 07:16 PM
sublimehemi
sandwich IL
1970 b body charger....i messaged Mccannix but no response yet...did they make one specific to 70 b body only?...yearone has them for 1970 hemi only and jacks has them 66-70...what the deal on this? i want one to bolt in...
[Re: 6bblgt]
#64617
12/17/12 01:13 AM
12/17/12 01:13 AM
Posts: 4,785 Ontario, Canada
mccannix
Ontario, Canada
That appears to be the 68-69 bracket Dan, although I have seen them on some 70's as well. I dont know why there are 2 different ones for 68-9 and then 70, as there is only one inch difference in the mounting hole but slotted openings for mount to the cooler body, perhaps a later design change or different vendor. Here are the different brackets, the wide one being the common drivers side. Top is Charger ( also installed on the repro cooler if ordered for a Daytona ), next is 70, then 68-69 and last on bottom is 66-67.
