Hemi Transmission Coolers #64608
05/27/08 03:51 PM
05/27/08 03:51 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
Does anyone else reproduce these Hemi Trans coolers
Is Jacks the only place who sells these ..
http://www.jacksautoparts.com/catalog/transmission.html
Re: Hemi Transmission Coolers [Re: sogtx] #64609
12/16/12 04:05 AM
12/16/12 04:05 AM
sandwich IL
sublimehemi Offline
sublimehemi  Offline
sandwich IL
bump...i know this thread is old but does anybody now where you can get a new one cheaper?
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
Re: Hemi Transmission Coolers [Re: sublimehemi] #64610
12/16/12 04:42 AM
12/16/12 04:42 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
If you are looking for a B body cooler what year. Brackets are a little different between years and if 1971 they all take the E Body style cooler. I can see if the person on moparts is still doing the coolers.
1971 HEMI E BODY REGISTRY
Re: Hemi Transmission Coolers [Re: hemicar1971] #64611
12/16/12 07:16 PM
12/16/12 07:16 PM
sandwich IL
sublimehemi Offline
sublimehemi  Offline
sandwich IL
1970 b body charger....i messaged Mccannix but no response yet...did they make one specific to 70 b body only?...yearone has them for 1970 hemi only and jacks has them 66-70...what the deal on this? i want one to bolt in...
Re: Hemi Transmission Coolers [Re: sublimehemi] #64612
12/16/12 07:48 PM
12/16/12 07:48 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
66-70 B-body all used the same cooler body and drivers side mounting flange bracket.
The difference lies in the bracket that mounts to the vertical rad center support.
66-67 used one, 68-69 used another, 70 used yet another, and Charger and Daytona used their own which was the longest bracket.
Pictured is the Charger and Daytona bracket.
Re: Hemi Transmission Coolers [Re: mccannix] #64613
12/16/12 08:21 PM
12/16/12 08:21 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Factory original 70 B-body cooler ( non-Charger style short bracket)
Re: Hemi Transmission Coolers [Re: mccannix] #64614
12/16/12 09:36 PM
12/16/12 09:36 PM
Manitoba, Canada
fjmg Offline
fjmg  Offline
Manitoba, Canada
Just an FYI, the daytona does not have the center vertical grill frame support and therefore cannot be secured in the same fashion as the charger. Creative must have stumbled on this dilema when the grill frame assembly was removed and the passenger side of the cooler was suddenly unsupported. They overcame this by crudely fabricating a piece of sheet metal that was "quickly" welded to the underside of the radyoke and extended down to the original mount holes in the cooler.
Re: Hemi Transmission Coolers [Re: fjmg] #64615
12/17/12 12:59 AM
12/17/12 12:59 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Which bracket set-up is this?
Re: Hemi Transmission Coolers [Re: 6bblgt] #64616
12/17/12 01:01 AM
12/17/12 01:01 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
& this was posted in the past
Re: Hemi Transmission Coolers [Re: 6bblgt] #64617
12/17/12 01:13 AM
12/17/12 01:13 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
That appears to be the 68-69 bracket Dan, although I have seen them on some 70's as well.
I dont know why there are 2 different ones for 68-9 and then 70, as there is only one inch difference in the mounting hole but slotted openings for mount to the cooler body, perhaps a later design change or different vendor.
Here are the different brackets, the wide one being the common drivers side.
Top is Charger ( also installed on the repro cooler if ordered for a Daytona ), next is 70, then 68-69 and last on bottom is 66-67.
Re: Hemi Transmission Coolers [Re: mccannix] #64618
12/17/12 01:32 AM
12/17/12 01:32 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
One like pictured in the engineering drawing doesn't exist? Hope you don't mind?
Re: Hemi Transmission Coolers [Re: 6bblgt] #64619
12/17/12 01:49 AM
12/17/12 01:49 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Dont mind at all.
I hope someone can show a picture of that one on a car then we'll know.
I can only offer the ones that have come off real coolers that were on the various factory cars.
Re: Hemi Transmission Coolers [Re: 6bblgt] #64620
12/17/12 09:00 PM
12/17/12 09:00 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I have another one slightly different than what is pictured. A buddy got a cooler assembly with a 68 Hemi Charger years ago. At the time I thought the brackets were the same for my 68 Hemi Road Runner so I made a couple of copies. I since found my original cooler w/brackets and it used the 68-9 version shown. I checked my "copied" brackets and they look like the squared off 70 version but they are about an inch longer than the 68-9 ones. The additional length is in the side with the single hole. It almost looks like the Daytona dimensions with different bends. We never used the cooler on that 68 Charger and no idea if it was original to the car or not. If the OP wants to try one, you are more than welcome to it, modify it as you need. Send me a PM with an address and I will get it out when I can.
Re: Hemi Transmission Coolers [Re: 68jim] #64621
12/17/12 09:17 PM
12/17/12 09:17 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I went out to the garage for a couple of pictures.
#1
Re: Hemi Transmission Coolers [Re: 68jim] #64622
12/17/12 09:19 PM
12/17/12 09:19 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
#2
