727 Question #646161
03/20/10 03:24 PM
03/20/10 03:24 PM
MD
Kevins493 Offline OP
MD
How much clearance do you guys like to run on the rear clutch pack? Mine's right at .044 and I'm wondering if it should be tighter.
Re: 727 Question [Re: Kevins493] #646162
03/20/10 05:41 PM
03/20/10 05:41 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
.030 t0 .040
Re: 727 Question [Re: Kevins493] #646163
03/20/10 10:25 PM
03/20/10 10:25 PM
NC
440Jim Offline
440Jim  Offline
NC
For the rear clutch (forward gears), I like it very tight. 0.025-0.035". Most of my builds are in the 20's. Too much travel works the belville spring, and way too much can cause it to go overcenter. Changing a standard 0.068" steel for an 0.088" will put you where I like to be. And they do make .070somethings.
The particular year factory manual I have says 0.025"-0.045" for 4 disc in the rear clutch.
Re: 727 Question [Re: 440Jim] #646164
03/20/10 11:24 PM
03/20/10 11:24 PM
MD
MD
Thanks Jim and Vern... I have an .088 retainer in it now. Is there anything thicker? And where can I find a part number?
Re: 727 Question [Re: Kevins493] #646165
03/22/10 01:49 PM
03/22/10 01:49 PM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
Mopar used to make a 0.106" ring. Not sure if they still have it. I can look up the P/N if you are interested.
Send me a PM or e-mail to remind me.
John
Re: 727 Question [Re: Kevins493] #646166
03/22/10 08:37 PM
03/22/10 08:37 PM
NC
440Jim Offline
440Jim  Offline
NC
I saved this info somebody posted years ago. I have one of those fat boys in my garage. I bought it new from the dealer in the fall of 2001 (2466811)
There are 4 different thickness FLAT snap rings
that can be used in the front & rear clutch drums.
0.060" P/N 1942063
0.074" P/N 1942064
0.088" P/N 1942065
0.106" P/N 2466811
For performance, should adjust clearance in the front clutch to 0.010" - 0.012" per
friction disc. So, 4 clutches should have around 0.040" - 0.048".
The rear clutch should be between 0.015" - 0.035
Here's the transtar numbers .
0.060" P/N 22601 chry # 1942063
0.074" P/N 22601A chry # 1942064
0.088" P/N 22601B chry# 1942065
0.106" P/N 22601C chry# 2466811 superceded to (??) 2766811
0.050" P/N 22601W ( waved???) chry# 3410570
Re: 727 Question [Re: 440Jim] #646167
03/23/10 05:37 AM
03/23/10 05:37 AM
virginia
572stealth Offline
572stealth  Offline
virginia
I put 2 wavy rings above the belville spring which cuts down on piston travel. Also use the late scalloped belville, less prone to breakage.
Re: 727 Question [Re: 572stealth] #646168
03/23/10 08:55 AM
03/23/10 08:55 AM
NC
440Jim Offline
440Jim  Offline
NC
Re: 727 Question [Re: 440Jim] #646169
03/23/10 10:06 AM
03/23/10 10:06 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Don,t forget the spacer ring also with the wave ring.
Re: 727 Question [Re: cl440] #646170
03/23/10 10:46 AM
03/23/10 10:46 AM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
And the spacer ring..one made out of pastic is thiner than the metal one..at lease the ones I got are..
