main bearings #646124
03/20/10 02:30 PM
03/20/10 02:30 PM
NJ
rth Offline OP
rth  Offline OP
NJ
installing my crank 68 440.main bearings coming up with .003,that sound right.thanks
Re: main bearings [Re: rth] #646125
03/20/10 02:35 PM
03/20/10 02:35 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
IMO it is real loose. I like .0015 and no looser than .002. Have sent shafts back that fit looser than .002 and had it reground to the next size. Street, strip, and circle. Never had a too tight failure yet.
Re: main bearings [Re: rth] #646126
03/20/10 03:01 PM
03/20/10 03:01 PM
See if you can locate some .001 under bearings. These were available from mopar way back then were not available for a long time and I think now they are available again (not MP but I think someone has them now)
Re: main bearings [Re: RapidRobert] #646127
03/20/10 03:25 PM
03/20/10 03:25 PM
Upper Midwest
Upper Midwest
001's may or may not help. Depends on what the shaft is ground too. If you have a .010 shaft a .001 bearing won't do you a heck of a lot of good. .001 bearings are meant to be used on a loose fit standard shaft.
Re: main bearings [Re: MoparforLife] #646128
03/20/10 03:52 PM
03/20/10 03:52 PM
NJ
rth Offline OP
rth  Offline OP
NJ
shaft was cut .010.rechecked clearances all .003.street motor i'm not happy with it being so big.machine shop already closed for weekend.
Re: main bearings [Re: rth] #646129
03/20/10 03:59 PM
03/20/10 03:59 PM
Upper Midwest
Upper Midwest
You could get by but it is like having a worn out engine to start out with. I would take it back and have it cut to .020 and tell them what you expect.
Re: main bearings [Re: MoparforLife] #646130
03/20/10 05:47 PM
03/20/10 05:47 PM
Relax.....003 is just fine
Honest..I build them everyday all kinds Mostly Mopar--That will work like a dream--no problems.
Lots of folks do it on purpose!
Re: main bearings [Re: ] #646131
03/20/10 06:26 PM
03/20/10 06:26 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Oil pressure might be a little low, an HV pump will take care of that.
Re: main bearings [Re: John_Kunkel] #646132
03/20/10 06:47 PM
03/20/10 06:47 PM
Upper Midwest
Upper Midwest
If the mains are that loose what are the rod bearings like. If they are that loose they will rattle, especially cold. Like said some would run it an like it but I wouldn't.
Re: main bearings [Re: MoparforLife] #646133
03/20/10 06:55 PM
03/20/10 06:55 PM
See if some .001"'s are available
Re: main bearings [Re: RapidRobert] #646134
03/20/10 07:36 PM
03/20/10 07:36 PM
NJ
rth Offline OP
rth  Offline OP
NJ
i didn't put pistons in yet but rod journals are within specs for a .010 cut according to my mic.
Re: main bearings [Re: RapidRobert] #646135
03/20/10 07:57 PM
03/20/10 07:57 PM
Upper Midwest
Upper Midwest
See if some .001's are available
Like I said above .001 bearings are for a loose standard shaft - not a .010 shaft.
Re: main bearings [Re: MoparforLife] #646136
03/20/10 08:20 PM
03/20/10 08:20 PM
No way it will rattle though
Listen...we do really big inch mean drag stuff with 3.8 or a tad more --They twist the crud out of the crank and you need it! Again--.003 is not like worn out--
I help my Dad with old farm tractors and we pull some down with .008 under the spec that were still plowing! Yep OP may have been a little low but .003 on a 440 crank journal is everyday good to go. Don't be scared and blow $$ for crazy hard to find bearings--OP may drop back at idle but I promise it will jump right up and honest that is the sign of a great build to me--on one you want to Haul!
Re: main bearings [Re: MoparforLife] #646137
03/20/10 09:03 PM
03/20/10 09:03 PM
I heard you the 1st time
Re: main bearings [Re: RapidRobert] #646138
03/20/10 10:26 PM
03/20/10 10:26 PM
Upper Midwest
Upper Midwest
Then why keep telling him to get a set of .001's.
Re: main bearings [Re: MoparforLife] #646139
03/20/10 10:32 PM
03/20/10 10:32 PM
I'm not telling him I am telling you. If he is 10 (or more) under then he knew from my 1st post that .001's would not be applicable
Re: main bearings [Re: rth] #646140
03/20/10 10:46 PM
03/20/10 10:46 PM
WI
Dcuda69 Online content
Dcuda69  Online Content
WI
You did not say how you measured that but......I have .003 on my 470"..been like that 3 yrs makes 80 psi cold and 30 psi hot idle. BBM's have big journals.. .003 is not out of line!!
Re: main bearings [Re: Dcuda69] #646141
03/20/10 10:53 PM
03/20/10 10:53 PM
NJ
rth Offline OP
rth  Offline OP
NJ
i measured the .003 with plastigauge. then removed crank and mic'ed it.
Re: main bearings [Re: rth] #646142
03/20/10 10:59 PM
03/20/10 10:59 PM
WI
WI
Mike'd what? Measure the shaft,then measure the housing with the bearing in it..the diff is clearance. My guess is if you see a REAL clearance of .003 I'd run it!!
Re: main bearings [Re: rth] #646143
03/21/10 09:21 AM
03/21/10 09:21 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Every spec ever shown that I have seen says .001 - .003
Period.
If anybody has reference to other specs, other than personal preference, I'd like to see them.
Personally, I would prefer .003 over .001. I like'em loose end and don't mind the noise, if any.
