Re: main bearings
[Re: rth]
#646126
03/20/10 03:01 PM
03/20/10 03:01 PM
RapidRobert
See if you can locate some .001 under bearings. These were available from mopar way back then were not available for a long time and I think now they are available again (not MP but I think someone has them now)
Re: main bearings
[Re: MoparforLife]
#646130
03/20/10 05:47 PM
03/20/10 05:47 PM
Relax.....003 is just fine Honest..I build them everyday all kinds Mostly Mopar--That will work like a dream--no problems. Lots of folks do it on purpose!
Re: main bearings
[Re: RapidRobert]
#646135
03/20/10 07:57 PM
03/20/10 07:57 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
If the mains are that loose
See if some .001's are available
Like I said above .001 bearings are for a loose standard shaft - not a .010 shaft.
Re: main bearings
[Re: MoparforLife]
#646136
03/20/10 08:20 PM
03/20/10 08:20 PM
No way it will rattle though Listen...we do really big inch mean drag stuff with 3.8 or a tad more --They twist the crud out of the crank and you need it! Again--.003 is not like worn out-- I help my Dad with old farm tractors and we pull some down with .008 under the spec that were still plowing! Yep OP may have been a little low but .003 on a 440 crank journal is everyday good to go. Don't be scared and blow $$ for crazy hard to find bearings--OP may drop back at idle but I promise it will jump right up and honest that is the sign of a great build to me--on one you want to Haul!
Re: main bearings
[Re: RapidRobert]
#646138
03/20/10 10:26 PM
03/20/10 10:26 PM
MoparforLife
Upper Midwest
I heard you the 1st time
Then why keep telling him to get a set of .001's.
Re: main bearings
[Re: MoparforLife]
#646139
03/20/10 10:32 PM
03/20/10 10:32 PM
RapidRobert
I'm not telling him I am telling you. If he is 10 (or more) under then he knew from my 1st post that .001's would not be applicable
Re: main bearings
[Re: rth]
#646142
03/20/10 10:59 PM
03/20/10 10:59 PM
Posts: 4,961 WI
Dcuda69
WI
i measured the .003 with plastigauge. then removed crank and mic'ed it.
Mike'd what? Measure the shaft,then measure the housing with the bearing in it..the diff is clearance. My guess is if you see a REAL clearance of .003 I'd run it!!
