Main bearing spacer #646117
03/20/10 02:18 PM
03/20/10 02:18 PM
Fla
Mike T Offline OP
Mike T  Offline OP
Fla
Does anyone know if anyone makes a main bearing spacer for use of a 400 crank in a 440 block thanks?
Re: Main bearing spacer [Re: Mike T] #646118
03/21/10 01:56 AM
03/21/10 01:56 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Why?
Re: Main bearing spacer [Re: Dodgem] #646119
03/21/10 01:37 PM
03/21/10 01:37 PM
Fla
Mike T Offline OP
Mike T  Offline OP
Fla
Because i need some
Re: Main bearing spacer [Re: Mike T] #646120
03/21/10 01:54 PM
03/21/10 01:54 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Well the make them for chevy's so phone clivite or other manufactures.
why would you want to put a 383/400 crank in a 440 block??
Re: Main bearing spacer [Re: Dodgem] #646121
03/21/10 02:59 PM
03/21/10 02:59 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: Main bearing spacer [Re: Dodgem] #646122
03/22/10 10:54 AM
03/22/10 10:54 AM
Fla
Mike T Offline OP
Mike T  Offline OP
Fla
i have a winberg crank that has 400 main size that i would like to put in my indy block that has 440 main size.
Re: Main bearing spacer [Re: Mike T] #646123
03/22/10 11:04 AM
03/22/10 11:04 AM
New York
polyspheric Offline
polyspheric  Offline
New York
How it was done back in the day:
1. install RB main bearing in the saddle
2. pin in place
3. hone to correct B bearing saddle ID
4. insert B bearings
Boffin Emeritus
