2765 Jaguar Fan Clutch RPM's #645691
03/20/10 01:28 AM
03/20/10 01:28 AM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
The Jag fan clutch is a thermal clutch. Locks up so to speak and spins faster when the engine is getting pretty hot. Now, let's say the engine is pretty hot and the fan clutch has locked up and is spinning faster, not slipping, and now the engine is turning about 6,000 RPM's. Can the clutch fan take that kind of RPM without coming apart? In other words, can a clutch fan spin safely at high RPM's?
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: 2765 Jaguar Fan Clutch RPM's [Re: Junky] #645692
03/20/10 01:42 AM
03/20/10 01:42 AM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
It will slip, so high RPMs should not be a problem,
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: 2765 Jaguar Fan Clutch RPM's [Re: HealthServices] #645693
03/20/10 02:00 AM
03/20/10 02:00 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Even at full tension, you still do not get a 1:1 ratio off of the clutch fan at higher rpms. The drag of pumping that air basically gets the clutch fan up to a point where it's rpm levels off and just won't go any higher or will barely go any higher. Or at least that's what I've been told. I wouldn't worry about it, I've never heard of anyone having trouble with fan clutches flying apart at high rpm.
Re: 2765 Jaguar Fan Clutch RPM's [Re: DaytonaTurbo] #645694
03/20/10 09:45 AM
03/20/10 09:45 AM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
OK, good. Thank you, guys!
Re: 2765 Jaguar Fan Clutch RPM's [Re: Junky] #645695
03/20/10 11:02 AM
03/20/10 11:02 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
those replacement clutches are kind of week in my opinion, they don't seem to lock up till higher temps 195/200 and don't lock up tight.
