Dyno new engine-worth it? #645473
03/19/10 10:30 PM
03/19/10 10:30 PM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
I'm running short on time to get my engine together and in the car to be ready for 1st pts race. How much does it normally cost to dyno a new engine? What usually is included?
I had machine work done (was even allowed to help with some of it) but I'm doing all the checking/fitting and final assembly myself, in my shop.
I'm concidering the dyno time to make sure that the engine is ready to go and broken in, no leaks, carb matched, timeing optimal ect. I think if I do go with the dyno time, I can put the engine in and go race right out of the trailer.
What do you guys think? Is it worth it?
Thanks, Brian
Re: Dyno new engine-worth it? [Re: '72CudaRacer] #645474
03/19/10 10:36 PM
03/19/10 10:36 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
around here 600.00 for the day...its good for A/f and knowing if you have any leaks.
Re: Dyno new engine-worth it? [Re: '72CudaRacer] #645475
03/19/10 10:39 PM
03/19/10 10:39 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
A good dyno operator can catch many problems before they take out a lot of expensive parts.
They keep tabs on a lot of things the average guy can't.
If you can afford it,it's not a bad option.
Re: Dyno new engine-worth it? [Re: '72CudaRacer] #645476
03/19/10 10:58 PM
03/19/10 10:58 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
You probably won't need a whole day Brian. I'd call around could get it done for maybe 450.00
I'll scoot down there and give it the back road tune for ya
Re: Dyno new engine-worth it? [Re: roadhazard] #645477
03/20/10 06:35 AM
03/20/10 06:35 AM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
I saw a huge benefit.
Caught some minor stuff during break in...tweaked it,,,and got the optimal power out of it..while on the dyno...well worth the money to me....
then when i dropped it into the car,,,i knew everything was fine,,,and didnt have to go thru months at the track of trying to figure out various problems,,,I think it saved alot of headache,,and perhaps time/money to get it right on the dyno,,,
Re: Dyno new engine-worth it? [Re: 69CHARGERMD] #645478
03/20/10 06:42 AM
03/20/10 06:42 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
only real dyno is the track dyno. sure it engine dyno's for max power but it needs to be track dyno'd for best et
Mopar Performance
Re: Dyno new engine-worth it? [Re: '72CudaRacer] #645479
03/20/10 07:59 AM
03/20/10 07:59 AM
Shelbyville, TN USA
40ford Offline
mopar addict
40ford  Offline
mopar addict
Shelbyville, TN USA
A dyno can help to optimize A/F ratio, ignition timing, spot leaks and seat all moving parts. Your engine will be ready to race when back from the shop.
A trip to a dyno is definitely worth the cost---even for a mild street engine. The last street engine we dynoed was about $400 total. Competition engines can cost a little more---about $500.
The costs in your area may be better----there are a lot of dynos in East TN.
Re: Dyno new engine-worth it? [Re: roadhazard] #645480
03/20/10 09:59 AM
03/20/10 09:59 AM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: Dyno new engine-worth it? [Re: '72CudaRacer] #645481
03/20/10 10:00 AM
03/20/10 10:00 AM
Scatchamatoon
Saskabusa Offline
Saskabusa  Offline
Scatchamatoon
Thanks, Brian
I paid around 600 bucks to have mine dyno'd. It was dyno'd at the shop that built the motor.
It's a good time saver. If there is a mechanical problem you'll know right away. You skip installing it in your car, driving to the track finding out you have a problem there and then having to fix it.
You get a chance to quickly see what a lot of tunning changes will do to your motor. It's a lot easier to change valve lash and carb jets whith the motor up on a dyno stand than in the engine bay of your car.
It's not a question of wether or not it's a good idea it definately is. It's a question of money and time. You could do all this at the track and you will have to make some adjustments there any way. Or you can skip a lot of the basic set up and go straight to the fine tunning.
If you have the money I would definately do it.
1974 Roadrunner
1967 Charger
Re: Dyno new engine-worth it? [Re: Old School] #645482
03/20/10 10:13 AM
03/20/10 10:13 AM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
...I wont mention any names...but I was in a far away place where there was no Mopar engine builders...so I went to a VERY well known Chevy engine builder (I know, I know)...he built the short block for my low deck stroker...part of the deal was a dyno session after I completed the build...made 5 dyno pulls...best pull was 782 hp...no signs of trouble engine sounded great...cut the filter apart, no signs of metal or foreign material...pulled it off of the dyno put it in the dragster and headed straight to the first race of the season. First pass it was 3 tenths slow, tuned on it, next pass it was a tenth off...3rd pass it grenaded big time, took out everything but the valve covers and intake manifold. The carnage was so bad we couldn't figure out what broke first...most likely cause was either too tight clearance on the 7/8 rod journal or it pulled the pin out of the piston on the #8 rod...so I guess my point is the extra cost of the dyno did me no good...and my next short block will be either built by myself or a reputable Mopar shop and I probably wont waste my money on dyno time.
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: Dyno new engine-worth it? [Re: '72CudaRacer] #645483
03/20/10 11:16 AM
03/20/10 11:16 AM
Az
Crizila Offline
Crizila  Offline
Az
Good to know where the torque and HP curves fall in to get your drive train in the ball park.
Fastest 300
Re: Dyno new engine-worth it? [Re: RapidusMaximus] #645484
03/20/10 04:23 PM
03/20/10 04:23 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I wouldn't let one bad experience put you off using this valuable tool of Race Engine Building. Like any tool, if not used properly you won't get the best results. There are several engine dynos near my house, but I would only ever choose to use one. Reason being the operator is an Engine Builder himself and is exceptional at spotting any problems that may arise. Sadly there are many dyno operators out there that will just sit in his chair and pull the handle.
Have a talk to some local racers and see who they use and go from there.
AL....
Alan Jones
Re: Dyno new engine-worth it? [Re: LA360] #645485
03/20/10 04:37 PM
03/20/10 04:37 PM
Missouri
galen Offline
galen  Offline
Missouri
I did not do mine, I wish I had as I am now trying to sort it out in car. I chose the wrong convertor and that cost me, I misjudged my horsepower and torque curve. Not to mention all the plugs and carb parts. Next engine for me will be dynoed. Galen
Re: Dyno new engine-worth it? [Re: galen] #645486
03/20/10 04:52 PM
03/20/10 04:52 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
I dyno every motor I have whenever possible. Will be heading to the dyno here pretty soon... not only is a day at the dyno fun the information gleened is valueable
Re: Dyno new engine-worth it? [Re: '72CudaRacer] #645487
03/20/10 04:58 PM
03/20/10 04:58 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
we had our engine dynoed..500 bucks and was worth it..carb was jetted, rockers set, dialed in the timing...you can even try different headers if available...
Re: Dyno new engine-worth it? [Re: smokinwoody] #645488
03/20/10 06:23 PM
03/20/10 06:23 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I'm tired of fighting it at the strip trying to dial it in there only to have chassis problems screw up my tuning session. On the 1st I take off to pick up a 2000 hp Land&Sea engine dyno for my garage. Hopefully I'll have it up and running sometime this summer.Dave
Re: Dyno new engine-worth it? [Re: quickd100] #645489
03/20/10 07:52 PM
03/20/10 07:52 PM
Trumbull,CT.
jim sciortino Online content
jim sciortino  Online Content
Trumbull,CT.
I wouldn't put an engine in my car without dynoing first.
Saves a ton of time and laps. Timing, leaks, HP & TQ #, etc., how can you possible know how to gear and converter a car without knowing what you have. Not just peak #s, but also where the power falls off.
And, if you have extra time and money, the ability to try different oils, fuels, curves, carbs, spacers, headers (if there happen to be multiple sets available) and so on, is invaluable.
An engine on the dyno is NOT exactly the same as an engine in a car making a run at speed, but the baselines from the dyno session will give you a headstart on zeroing the combination.
PERIOD!!!!
Re: Dyno new engine-worth it? [Re: quickd100] #645490
03/20/10 08:31 PM
03/20/10 08:31 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Ya don't say , neighbor ?
I will have mine done before then , but I am using R&R in Spring Lake Park.
They are doing the heads now and though they aren't MoPar guys per se , they are highly recommended and have been at it for a good while.
Like most of you have stated , it will be instrumental in deciding my converter and nice to know some baseline tuning.
Especially since this will be my first trip down E-85 lane.
Re: Dyno new engine-worth it? [Re: jim sciortino] #645491
03/20/10 08:58 PM
03/20/10 08:58 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
PERIOD!!!!
Well said
not to mention knowing your fuel curve
Don't hurt to ask around and see who you might trust with their tuning abilities. I won't mention names but not all dyno's and operators are created equal so talk to someone you know that has good first hand info.
Re: Dyno new engine-worth it? [Re: roadhazard] #645492
03/22/10 05:11 AM
03/22/10 05:11 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
Good to know. The engine builder i've got lined up builds 2000HP Chevy engines, but has a lot ov experience with racing a Mopar 383 back in the day. He has a dyno and said it'd run around $500 extra to dial it in and give me some numbers, try a couple things, etc. Sounds like a deal. Personally, i was leaning towards doing that, but after reading this thread i think i'll hold off on the build till i've got that extra 5 bills.
