hemi carburetors #644916
03/19/10 11:33 AM
03/19/10 11:33 AM
Suffolk,VA
dragracedr Offline OP
Suffolk,VA
Anyone have any baseline mods for 770 cfm hemi crossram carbs? Will be on 528 c.i. aluminum hemi, 13.5:1 CR, port-matched MP crossram. Looking at ballpark jetting, base-plate mods, Metering block changes. I will do the usual - low profile throttle blade screws, etc.
Re: hemi carburetors [Re: dragracedr] #644917
03/19/10 06:05 PM
03/19/10 06:05 PM
76 primary and 75 secondary. thats a good starting point depending on your DA.
i went with the quickfuel metering blocks so i could change the jets in the secondaries instead of the metering plate which is a fixed jet size. hope this helps.
Re: hemi carburetors #644918
03/19/10 06:39 PM
03/19/10 06:39 PM
Suffolk,VA
Suffolk,VA
thanks. That's a start. The engine will be dyno'ed and that's a baseline.
Re: hemi carburetors [Re: dragracedr] #644919
03/22/10 10:50 AM
03/22/10 10:50 AM
Oregon,USA
RAT PATROL Offline
RAT PATROL  Offline
Oregon,USA
How hard could it be? I straightened my carbs out, so well that it wouldn't even run on 8. Off to Barton and they came back converted back to plates with 80 jets and a bag full of parts, with stronger midrange. Now the "experts" don't complain about the wrong carbs.
