Re: rusty distributor [Re: Quicktree] #644862
03/19/10 05:10 PM
03/19/10 05:10 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
What no barn ...... But where do all your pinion angles live
Re: rusty distributor [Re: emarine01] #644863
03/19/10 05:38 PM
03/19/10 05:38 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I have a tent out back that I keep all my angles in.
Re: rusty distributor [Re: Quicktree] #644864
03/19/10 06:04 PM
03/19/10 06:04 PM
Lehigh Acres, Florida
rickstershemi Offline
I've heard rust stories, but have never had a problem, but I also do the WD40 trick
Rickster
Re: rusty distributor [Re: rickstershemi] #644865
03/19/10 06:31 PM
03/19/10 06:31 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
i've had the same problem with my MSD distributor rotting and wonder if venting the cap would help. high voltage discharges (read sparks) generate ozone which is very corrosive and i wonder if that could be causing or adding to it. maybe someone should send this thread to MSD and see what they say. i can tell you one thing it is not an isolated incident.
Re: rusty distributor [Re: jamesc] #644866
03/19/10 07:39 PM
03/19/10 07:39 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I've had the same issues and wonder if it's just condensation build up
Re: rusty distributor [Re: roadhazard] #644867
03/19/10 07:59 PM
03/19/10 07:59 PM
jamesc Offline
jamesc  Offline
could be, could be ozone and moisture. either way venting it would probably help
Re: rusty distributor [Re: jamesc] #644868
03/19/10 11:19 PM
03/19/10 11:19 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
With the WD40 trick make sure the stuff dries up a little before you light the thing off as WD40 is extremely flammable - Did the WD40 trick one late night at the norwalk halloween classic - because of the heavy dew. I can tell you a mopar cap will not hold the explosion and be functional for next round!
Re: rusty distributor [Re: jamesc] #644869
03/19/10 11:51 PM
03/19/10 11:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Maybe a anode would help..... I spray my dist with
wd40 every couple years and let it sit upside down
over night then put it in(lets it drip dry), still
looks good in there
Re: rusty distributor [Re: MR_P_BODY] #644870
03/20/10 07:58 AM
03/20/10 07:58 AM
Greenville, WI
Big B Offline OP
Big B  Offline OP
Greenville, WI
Well I removed all the rust, sprayed it with WD40, put it back
In, and it fired right up. Guess I'll just keep spraying it a
Couple times/year from now on.
