440 HP Exhaust manifolds vs. Headers... #64433
05/27/08 11:41 AM
05/27/08 11:41 AM
CH
P
plyrr69 Offline OP
plyrr69  Offline OP
P
CH
Hello
I have some Headers in my Runner. I have heard that the original HP Exhaust Manifolds have the performance close to my headers... is there a truth about that, or is it just a story? i am thinking to come close to something like F.A.S.T Cars, original looking with performance... with exhaust manifolds!
___________________________ .......plymouth tells it like it is...!
Re: 440 HP Exhaust manifolds vs. Headers... [Re: plyrr69] #64434
05/27/08 11:51 AM
05/27/08 11:51 AM
AndyF Online content
AndyF  Online Content
I wouldn't say the performance is the same, it is just that you can go plenty fast with manifolds. It is rather easy (given the resources) to build a car that looks fairly stock yet has the ability to run 11.50 at the strip.
If you aren't going to put a roll bar in the car then you run the manifolds. There really shouldn't be too much of a problem of getting a big block with manifolds deep into the 11's.
Re: 440 HP Exhaust manifolds vs. Headers... [Re: plyrr69] #64435
05/27/08 11:52 AM
05/27/08 11:52 AM
toronto canada
69chargeryeehaa Offline
toronto canada
Just my here but i'm totally done with headers. My 69 charger r/t stock 440, had headers, they leak both at the head and the studs (coolant), higher underhood temps, too much heat for the starter, and they are a TOTAL PAIN IN THE ANUS TO GET IN/OUT. So i got a used set of the HP manifolds and a TTi 2.5 with h-pipe, installed them (which was so easy it wasn't funny, i did it twice just because it didn't feel right!!!!) and the car actually runs MUCH better, i did'nt notice a performance decrease at all. Just for the ease of working with them, and how much eaiser it is to work on the car (plugs, starter, steering box, ect....) i will never run headers again!.
Re: 440 HP Exhaust manifolds vs. Headers... [Re: plyrr69] #64436
05/27/08 12:22 PM
05/27/08 12:22 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Hello
no way. The FAST guys sink $$$ into their mani's and if they could they'd all run headers. Not saying you can't run fast with mani's but you'll pretty much always run better with headers. Especially on anything over stock build. I'd leave them on unless you are planning on entering a restrictive class like FAST or factory stock.
Re: 440 HP Exhaust manifolds vs. Headers... [Re: Mr.Yuck] #64437
05/27/08 12:38 PM
05/27/08 12:38 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Hello
The FAST guys have all sorts of fancy extrude honing done, but the Pure Stock guys don't.
I think Andy pretty much nailed it. The headers ARE going to give you a performance boost all things being equal, BUT whether it's a minor improvement or a major one depends on the build and power levels.
You really get two separate schools of thought on this question whenever it comes up;
- 1) Headers are always better, why not run them.
- 2) If your goal is X horsepower, it can be done with manifolds.
....it really depends on what you're looking for.
I also think that people tend to forget that the exhaust system works as a system; a nicely done 2 1/2" mandrel bent system with an X pipe, hi flow mufflers and HP manifolds may well flow better than a set of cheapee headers, 2 1/4" compression bent pipes and crappy mufflers.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 440 HP Exhaust manifolds vs. Headers... [Re: Mr.Yuck] #64438
05/27/08 12:53 PM
05/27/08 12:53 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
In an old issue of Mopar Muscle the stock manifolds cost 80 HP on a 500HP motor. I think with a full exhaust the differance may no be that much but a GOOD set of headers will alway make more power. Some FAST cars have cams with wide LSAs to help make power with the restrictive exhaust manifolds...Most of the faster ones have higer compression like 14 to 1 and run on race gas only. I really like the stock look of these cars and there amazing performance but the faster ones are not every day drivers and are far from stock.
Re: 440 HP Exhaust manifolds vs. Headers... [Re: THESHAKERPROJECT] #64439
05/27/08 01:35 PM
05/27/08 01:35 PM
The low deck 470 in my B body car was a fairly inexpensive motor to build. Unported Edelbrock heads, Performer RPM intake, Eddy 800 cfm carb, Mopar Perf .528 solid cam, etc.
With the HP exhaust manifolds and a 3 inch exhaust system it would spin 475 RWHP on the chassis dyno all day long. That is more rear wheel horsepower than a lot of Vettes, Vipers, Mustangs, etc.
That engine idled at 800 rpm with plenty of vacuum and drove around town pretty easily. Compression was 10.5 so it ran just fine on pump gas premium.
475 RWHP will put a B body deep into the 11's if a person has the chassis setup correctly. My car would run low 12's at 115 mph on radial street tires when I took it to the track.
Re: 440 HP Exhaust manifolds vs. Headers... [Re: THESHAKERPROJECT] #64440
05/27/08 01:35 PM
05/27/08 01:35 PM
DPelletier Offline
DPelletier  Offline
That would be inaccurate. There MAY be a 80hp difference on a particular 500hp motor, but it is completely dependant on the build (and more specifically the camshaft). As you mentioned, there are cams out there designed to work with manifolds.
I also agree that the competitive FAST stuff isn't really streetable. Cool, but not practical and that's why I've chosen to go the Pure Stock route.
Re: 440 HP Exhaust manifolds vs. Headers... [Re: AndyF] #64441
05/27/08 01:40 PM
05/27/08 01:40 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
just think how well it would run with headers and a good carb, like a double pumper!
Re: 440 HP Exhaust manifolds vs. Headers... [Re: DPelletier] #64442
05/27/08 01:43 PM
05/27/08 01:43 PM
It would be fairly easy to "cook the books" in a headers vs. manifold shoot out but just selecting a camshaft with a bunch of overlap. The high overlap cam will do pretty good with open headers on a dyno but would be a real dog with the more restrictive manifolds.
I'd say it would also be fairly easy to take the same identical engine and only change the camshaft and have a completely different test result.
Re: 440 HP Exhaust manifolds vs. Headers... [Re: AndyF] #64443
05/27/08 02:30 PM
05/27/08 02:30 PM
DPelletier Offline
DPelletier  Offline
Yeah, that's what I was thinking.
Re: 440 HP Exhaust manifolds vs. Headers... [Re: plyrr69] #64444
05/27/08 03:06 PM
05/27/08 03:06 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
With all the issues there are with headers - rusting, fit, performance, accessability, ease of installation, etc. it makes me wonder why someone hasn't started to produce a decent set of cast manifolds aimed at the street/strip guys. With today's casting technology you wouldn't think it would be that much trouble - cetainly no more labor intensive than welding pipe together.
Re: 440 HP Exhaust manifolds vs. Headers... [Re: Stanton] #64445
05/27/08 03:37 PM
05/27/08 03:37 PM
dogdays Offline
dogdays  Offline
Sanderson makes cast iron headers for chevy smallblocks. I saw a pair on a '34 chevy coupe a week ago. More interesting to me were the forged aluminum suspension arms of the Corvette rear end. It looked mighty sanitary.
R.
Re: 440 HP Exhaust manifolds vs. Headers... [Re: Stanton] #64446
05/27/08 04:33 PM
05/27/08 04:33 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I don't know why people have some many problems with headers. I've had several sets. Cheapos too. strip them and paint them w/ a good high heat paint and they last a looong time. Don't over torque the bolts and they won't leak, don't drive like a duke boy and they won't drag the ground. leave the mani studs in or use long header bolts w/ a tab of sealer and they won't drip coolant. I don't see why anybody (besides the #'s matching, FAST pure stock guys) would wanna run logs.
Re: 440 HP Exhaust manifolds vs. Headers... [Re: plyrr69] #64447
05/27/08 05:24 PM
05/27/08 05:24 PM
Talking with Tom at accurate exhaust he told me that there would be very little difference. Most guys out think themselves and don't realize they need back pressure. Tom put together a great exhaust system for me. I also talked with a super stock racer and he said the only place you would see a difference would be top end.Since I don't drag race thats all I needed to hear. I was tired of the heat, low clearence and the engine was hard to work on so there gone.
Thanks Moparts
Re: 440 HP Exhaust manifolds vs. Headers... [Re: Mr.Yuck] #64448
05/27/08 05:31 PM
05/27/08 05:31 PM
NORTHERN VA
NORTHERN VA
and what is a good pair of used rusted pitted manifolds goin for these days...$400 or more ?
Re: 440 HP Exhaust manifolds vs. Headers... #64449
05/27/08 05:33 PM
05/27/08 05:33 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Thanks Moparts
pleace explain the real facts about why a fourstroke engine needs backpreasure?
long tube headers only making an improvement in highrpm power? dont realy believe in that one either please someone show some facts about it..
i fully understand if the benefits of headers are not worth the heat, groundclearance, sound or other obstacels but those things above are not anything i would fully trust, sorry if it looks like i look like bad guy in this post i just don get this...
Re: 440 HP Exhaust manifolds vs. Headers... #64450
05/27/08 06:13 PM
05/27/08 06:13 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
... Most guys out think themselves and don't realize they need back pressure.
Sorry, but that's crap. Back pressure is BAD; you want as little back pressure as possible in a performance application.
What you have to take into account is most engines (especially in near-stock configuration) aren't tuned for a no/low-backpressure exhaust system. That's why some people mistakenly think that some backpressure is good... because they haven't made the rest of the tuning adjustments to handle an improved exhaust system.
Re: the original question... yes, a good set of headers are definitely worth power over a set of OEM HP exhaust manifolds. As others pointed out, how much depends on a lot of factors. However, on something like a mild-to-moderate 440 street engine, I'd say it's a safe bet that switching from HP iron manifolds to a good set of properly-sized headers for the application would be worth 20-40 HP and a comparable amount of torque.
Re: 440 HP Exhaust manifolds vs. Headers... [Re: BradH] #64451
05/27/08 07:28 PM
05/27/08 07:28 PM
1 3/4" headers, theres little difference. 1 7/8" you'll start to notice a difference. 2" headers theres ZERO comparison.
Re: 440 HP Exhaust manifolds vs. Headers... #64452
05/27/08 07:47 PM
05/27/08 07:47 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Headers will always make more hp and torq. How much depends on the rest of the combo. Now you can make a lot of power with manifolds and go quick down the 1/4 with them, however if you're wanting to get everything possible out of your combo(and not willing to pay stupid high $ for OEM hp manifolds) chances are you'll have headers on there.
