Slotted and cross drilled disc brake kits
#644201
03/18/10 04:51 PM
03/18/10 04:51 PM
Posts: 9,404 Texas
carcrazyguy
Texas
I am trying to decide on a brake kit for my 70 Duster. I am looking for a slotted and cross drilled kit with nice calipers that will clear 15 inch wheels. Any suggestions??
Anyone using this setup....?
DoctorDiff 13" front disc brake kit includes loaded Cobra calipers, billet aluminum caliper brackets, rotors, hubs, bearings, seals, dust caps, stainless flex lines and hardware. All new parts $800
DoctorDiff 10.7" rear disc brake kit includes loaded Cobra calipers with internal parking brake, billet aluminum caliper brackets, rotors, stainless flex lines and hardware. All new parts $625
Re: Slotted and cross drilled disc brake kits
[Re: pishta]
#644204
03/18/10 11:03 PM
03/18/10 11:03 PM
Posts: 5,784 Corpus Christi, TX
shanker
Corpus Christi, TX
go slotted but not drilled unless its a track car.
I got mine from rotorpro's, they have the best prices shipped compared to anyone else (just replacement rotors though.
The Federal Government has not yet learned that you cannot legislate morality
1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23
1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55
1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91
1975 Duster 360 VS29L5 Daily Driver
[Re: AndyF]
#644207
03/19/10 07:58 PM
03/19/10 07:58 PM
Posts: 9,404 Texas
carcrazyguy
Texas
You can also run the 11.75 kit with Viper calipers. Mancini Racing has this kit for sale. Various vendors offer the Mopar 11.75 rotor drilled and slotted.
I am going with a 73-later spool type K member. The Viper caliper kit is what I am looking for but had not seen a Viper caliper used with a 11.75 rotor. Thought maybe you had to use a 13" rotor for the Viper caliper.
This car may not get 500 miles a year but for some reason I want cross drilled and slotted rotors?? If I can not go fast, or corner on rails, might as well look that part. ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: shanker]
#644212
03/20/10 12:51 AM
03/20/10 12:51 AM
Posts: 7,647 Houston Texas
PAINT IT BLACK
Got a CHIP on my shoulder
Houston Texas
I have a set of cross drilled rotors from Baer and they cracked at the cross drilled holes.
thats common for drilled rotors, which is why I said in my above post that they are not for street use...
Meh... I have them on my '06 M3 and my '05 TL and they are fine... used and abused on the street... ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: PAINT IT BLACK]
#644213
03/20/10 10:39 AM
03/20/10 10:39 AM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Lots of Mercedes have drilled rotors, and not just the AMG cars. The difference is in how the rotor is made. Lots of aftermarket cheapie rotors are drilled after casting. Those rotors will crack when abused. The Merciless Bends stuff is cast with the holes. It's a more expensive rotor to cast but they don't crack.
[Re: DoctorDiff]
#644219
08/30/10 02:29 PM
08/30/10 02:29 PM
Posts: 1,491 Lethbridge, AB, Canada
dangina
The 13" front disc brake kit will not fit 15" wheels, but I also offer a couple reasonably priced 11.75" kits that will clear 15" wheels.
Drilled/and/or/slotted/plated rotors are optional on all my kits.
are your brakes single,2,4, or 6 piston calipers?
