I seem to have a local debate going here on the correct application of these covers.. they were marked 68 gts..Couple guys I know say 67 r/t gtx.. I thought the 67s had a spark plug wire tab on the rear of the driver side cover? These are as follows, 3 wiring harness tabs on inside of rh cover, 1 spark plug tab on inside of rh cover, 1 spark plug tab on rear of rh cover.. LH cover has no spark plug tabs, just the oil tube.. Thanks in advance for the ID help..
