Chrome factory BB valve covers help to ID 67 68 69 #643749
03/18/10 09:10 AM
03/18/10 09:10 AM
massachusetts
P
Provan Offline OP
Provan  Offline OP
P
massachusetts
I seem to have a local debate going here on the correct application of these covers.. they were marked 68 gts..Couple guys I know say 67 r/t gtx.. I thought the 67s had a spark plug wire tab on the rear of the driver side cover? These are as follows, 3 wiring harness tabs on inside of rh cover, 1 spark plug tab on inside of rh cover, 1 spark plug tab on rear of rh cover.. LH cover has no spark plug tabs, just the oil tube.. Thanks in advance for the ID help..
76 DODGE VAN PRO STREET 67 DODGE CORONET R/T 480 STROKER
Re: Chrome factory BB valve covers help to ID 67 68 69 [Re: Provan] #643750
03/18/10 12:13 PM
03/18/10 12:13 PM
Champlin Mn.
2
2DoorPost Offline
2DoorPost  Offline
Champlin Mn.
The set I have are from a 68 383 barracuda,which do not have the bracket for the heater hoses so I guess thats the way the factory did it for my car!
Re: Chrome factory BB valve covers help to ID 67 68 69 [Re: 2DoorPost] #643751
03/18/10 01:44 PM
03/18/10 01:44 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Valve covers shown are '67 b-body (GTX & R/T) the a-body driver's side has 2 plug wire brackets for #7.
