axel in spool #643670
03/18/10 12:31 AM
03/18/10 12:31 AM
bc canada
67valiant Offline OP
bc canada
how far should the axel be in the spool and whats the min they should be ??
Re: axel in spool [Re: 67valiant] #643671
03/18/10 12:52 AM
03/18/10 12:52 AM
I like to see the axles splines fit past the inside edge of the spool splines. there are some spools that are splined all the way thru so that won't work on them,the ones that I have measured that are not full lenght splines have 1.5 to 2 inches of splines on each side with about a two inch space between them on the inside. I hope that makes sense I have several Strange and Yukon 35 spline spools for a 8 3/4 that I could measure in the morning to make sure, if needed. let me know if needed
Re: axel in spool [Re: Cab_Burge] #643672
03/19/10 12:54 AM
03/19/10 12:54 AM
bc canada
bc canada
that would help if you could and better if ya took pic too that way it might say me taking out the 3rd member ifit dont look right i was also thinking that i could measure the stock ones to see how close they are to the other ones as im not sure of the measurement of the strange axels i was told they were cut 1 " shorter but they might be close
Re: axel in spool [Re: 67valiant] #643673
03/19/10 01:04 AM
03/19/10 01:04 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Stock 8 3/4" axle end gap is 1.5".
Most spools have a 1.25" gap in the center of the splines.
Re: axel in spool [Re: 67valiant] #643674
03/19/10 05:07 PM
03/19/10 05:07 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Min Spline engagement is .750". Length of available spline is dependant on axle manufaxturer.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: axel in spool [Re: W.I.N. Racing] #643675
03/21/10 11:33 PM
03/21/10 11:33 PM
bc canada
bc canada
thanks guys for the info
