Page 1 of 6 1 2 3 4 5 6
It has begun!!! Demon is getting a face lift..STRIPED! #643415
03/17/10 10:18 PM
03/17/10 10:18 PM
Finally a HUSKER again
Moparnut426 Offline OP
Well I got the engine compartment done, got all the wireing cleaned up, I rewrapped some of the wireing. Rerouted my power wire so its more fire free. Started on getting the body work done. Cut my what looked like a 50 cent spot of rust out, and it ended up a LOT bigger. Sucked my rocker pannel clean, over the last 12 years little critters made a few nests in my car. Got the new bullit 90% done, so as soon as the stroker is done its getting dropped inn.
What ya think??
Kasey
Re: It has begun!!! Demon is getting a face lift.. [Re: Moparnut426] #643416
03/17/10 10:20 PM
03/17/10 10:20 PM
Body work,, Thats my budy Lee, hes pretty good at his Job!!
Re: It has begun!!! Demon is getting a face lift.. [Re: Moparnut426] #643417
03/17/10 10:21 PM
03/17/10 10:21 PM
Mor of the body work
Re: It has begun!!! Demon is getting a face lift.. [Re: Moparnut426] #643418
03/17/10 10:23 PM
03/17/10 10:23 PM
The spot got bigger, naturally
Re: It has begun!!! Demon is getting a face lift.. [Re: Moparnut426] #643419
03/17/10 10:26 PM
03/17/10 10:26 PM
Engine bay where I rerouted my Power wire.. Under my trany hump, along the factory pinch weld protected from any harm.
Re: It has begun!!! Demon is getting a face lift.. [Re: Moparnut426] #643420
03/17/10 10:27 PM
03/17/10 10:27 PM
more wireing
Re: It has begun!!! Demon is getting a face lift.. [Re: Moparnut426] #643421
03/17/10 10:30 PM
03/17/10 10:30 PM
Here are some before paint.
The new wireing is way cleaner. In the future, I plan on buying brand new dash, and engine/headlight wireing from year one. I cant believe how hard it is to fing "GOOD" used ralley cluster wireing for an A body.
Re: It has begun!!! Demon is getting a face lift.. [Re: Moparnut426] #643422
03/18/10 12:46 AM
03/18/10 12:46 AM
Freeport, Pa
W
whiskeyrunner Offline
W
Freeport, Pa
you need to paint it a different color
Re: It has begun!!! Demon is getting a face lift.. [Re: whiskeyrunner] #643423
03/18/10 01:00 AM
03/18/10 01:00 AM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
looks good, you repainting the whole thing then?
Re: It has begun!!! Demon is getting a face lift.. [Re: Joshs68] #643424
03/18/10 01:11 AM
03/18/10 01:11 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Very nice work. Ron
Re: It has begun!!! Demon is getting a face lift.. [Re: Joshs68] #643425
03/18/10 08:19 AM
03/18/10 08:19 AM
Yep, The whole things getting fresh paint, properly blocked out, cut and buffed, and a stripe kit finally!!
Kasey
Re: It has begun!!! Demon is getting a face lift.. [Re: Moparnut426] #643426
03/18/10 08:16 PM
03/18/10 08:16 PM
Got a little work done today on the engine. Getting really close now. I bought the Hughes thick walled rocker shafts, but they have small holes in them. My heads have 3/8 bolts and wont fin in the new shafts, Is it gonna be ok to just drill them out for the heavier rocker shaft bolts. I have one head torqued on, all the lifters in, and am now waiting on the rocker bolt issue.
Re: It has begun!!! Demon is getting a face lift.. [Re: Moparnut426] #643427
03/18/10 08:17 PM
03/18/10 08:17 PM
More of the fun.
Re: It has begun!!! Demon is getting a face lift.. [Re: Moparnut426] #643428
03/18/10 08:19 PM
03/18/10 08:19 PM
More and More fun!!
Re: It has begun!!! Demon is getting a face lift.. [Re: Moparnut426] #643429
03/18/10 08:22 PM
03/18/10 08:22 PM
one more
Re: It has begun!!! Demon is getting a face lift.. [Re: Moparnut426] #643430
03/18/10 08:49 PM
03/18/10 08:49 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
Looking good! I like the way those heads look..are those Brodix? or...
Re: It has begun!!! Demon is getting a face lift.. [Re: B1Fish540] #643431
03/18/10 08:53 PM
03/18/10 08:53 PM
Yep Brodix!! I really like them.
Thank RANDY!!!!!
Re: It has begun!!! Demon is getting a face lift.. [Re: Moparnut426] #643432
03/18/10 10:49 PM
03/18/10 10:49 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
Yer welcome Kasey!! Glad everything is finally coming together for you
Re: It has begun!!! Demon is getting a face lift.. [Re: b1dartsport] #643433
03/18/10 10:53 PM
03/18/10 10:53 PM
Man its been a long trip, but Its going in the straight and narrow, hopefully in the 12 second range!!
Re: It has begun!!! Demon is getting a face lift.. [Re: Moparnut426] #643434
03/18/10 11:04 PM
03/18/10 11:04 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
If it runs twelves you need to figure out which plug wires came off!
68 Barracuda Formula S 340
