B1 intake bolt pattern Question #643288
03/17/10 08:18 PM
03/17/10 08:18 PM
Anonymous OP
Anonymous OP
is the intake bolt pattern the same for the B1 original heads and the B1 MC heads or are they different like the TS heads?
looking to try a intake swap.thanks
Re: B1 intake bolt pattern Question #643289
03/17/10 09:43 PM
03/17/10 09:43 PM
new jersey
gillman34 Offline
gillman34  Offline
new jersey
same
Re: B1 intake bolt pattern Question [Re: gillman34] #643290
03/17/10 10:27 PM
03/17/10 10:27 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Yep, I just got off the Phone W/ Scott and said they are the same but you may need intake risers depending on the application.
The TS heads have a different bolt pattern though.
Re: B1 intake bolt pattern Question [Re: WILD BILL] #643291
03/18/10 07:34 AM
03/18/10 07:34 AM
Anonymous OP
Anonymous OP
SO MY NEXT QUESTION IS,
ARE THE INTAKE PORTS the same on both heads.
best machine made me a set of intake adapter plates to put a indy 440-25 crossram on a set of b1 original heads, but looking to put these adapter plates on some b1-mc heads and use the adapter plates to match up the indy intake for dual carb setup to the mc heads. i'm still learning these B1 head configurations.
thanks wildbill and steve G.
Re: B1 intake bolt pattern Question #643292
03/18/10 12:43 PM
03/18/10 12:43 PM
huron,ohio
b1headman Offline
b1headman  Offline
huron,ohio
Port location is the same for both heads.
Re: B1 intake bolt pattern Question #643293
03/18/10 08:07 PM
03/18/10 08:07 PM
saint paul mn
fasteddie5250 Offline
saint paul mn
what do they look like I have a b1 and was looking at how I could do it how much did it cost
Re: B1 intake bolt pattern Question [Re: fasteddie5250] #643294
03/18/10 11:21 PM
03/18/10 11:21 PM
Anonymous OP
Anonymous OP
You have to port match the spacers to the intake and the head. The spacers are not a bolt on deal.
Re: B1 intake bolt pattern Question #643295
03/18/10 11:52 PM
03/18/10 11:52 PM
saint paul mn
saint paul mn
IS this a low deck or tall deck one i have is a low deck 468 so i would not have as much space as a tall deck that would be a big angle to match
