O ringed block #642534
03/16/10 10:54 PM
03/16/10 10:54 PM
p.a.
BUTCH123 Offline OP
BUTCH123  Offline OP
p.a.
I have a 60 over 440 block that has been o ringed. one has come out. How do I reinstall it? DO I HAVE TO BUY NEW ONES? Why is this done?
Re: O ringed block [Re: BUTCH123] #642535
03/17/10 04:53 AM
03/17/10 04:53 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
maybe check the rest to be sure thay are tight in the grooves.i think the wire is .050 stainless and maybe an engine shop near you can cut you a piece.it gets tapped in with a small hammer keeping it flat and mark it for the cut when you get it close.it is done for sealing in combustion pressure with cr over 14/1 and NOS use.
Re: O ringed block [Re: blownzoom440] #642536
03/17/10 05:49 AM
03/17/10 05:49 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i had a block that was O ringed. i just used Mig wire that was a firm fit. just file the end square & tap it into place with the small hammer as previously suggested. when you get to the end cut it very close & file up that end too. it's a no brainer, takes a few minutes. you could try & refit the one you have if it's not bent or kinked. ask a welder for 12" of wire, he'll probably give it to you.
Re: O ringed block [Re: BUTCH123] #642537
03/17/10 06:19 AM
03/17/10 06:19 AM
Measure the diameter of the wire first, try reusing it second and then use some new wire of the same size if the old won't work. I have seen many different sizes used by different shops as well as some use soft copper wire and some use stainles wire
Re: O ringed block [Re: Cab_Burge] #642538
03/17/10 10:39 PM
03/17/10 10:39 PM
p.a.
BUTCH123 Offline OP
BUTCH123  Offline OP
p.a.
THANKS GUYS I KNEW I COULD COUNT THE COMMUNITY FOR HELP. PAT
Re: O ringed block [Re: BUTCH123] #642539
03/18/10 08:08 AM
03/18/10 08:08 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
As stated I'd probably just reinstall the original one...IF THEY WORKED BEFORE. Use the same style gasket too!!! You can use a composite gasket if the 'rings' don't intersect. Maybe run a height guage across the peaks to see how tall they are and if they're the same. I've used S.S. but, as stated measure the grove width and match the wire if replacing. I file the seam at a diagonal for a 'zero' gap effect. I've (heard) of some success by just remove the ring completely and filling the void with 'grout'. So there's some more options for you.
Re: O ringed block [Re: HardcoreB] #642540
03/18/10 08:04 PM
03/18/10 08:04 PM
Sao Paulo, Brazil
dart_73_br Offline
dart_73_br  Offline
Sao Paulo, Brazil
Anyone knows a similar and cheapier tool than that iskenderian groove-o-matic ?
Re: O ringed block [Re: Cab_Burge] #642541
03/18/10 09:15 PM
03/18/10 09:15 PM
Ft.Myers,Florida
Hemiruss Offline
Hemiruss  Offline
Ft.Myers,Florida
I had wire on the heads and used copper gaskets on the hemi. You can reuse the copper gaskets you just have to burnish them
Re: O ringed block [Re: Hemiruss] #642542
03/18/10 09:16 PM
03/18/10 09:16 PM
Ft.Myers,Florida
Hemiruss Offline
Hemiruss  Offline
Ft.Myers,Florida
Block
Re: O ringed block [Re: dart_73_br] #642543
03/19/10 07:26 AM
03/19/10 07:26 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
You want cheaper?...Have a pro do it. I used to have the Isky tool and it worked well and IMO it's priced reasonably. I wouldn't bargain hunt with machining that could potentially ruin the block though. Just my
Post deleted by Defbob [Re: HardcoreB] #642544
03/19/10 08:53 AM
03/19/10 08:53 AM
Re: O ringed block #642545
03/19/10 09:03 AM
03/19/10 09:03 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Worked on my small block
