Ignition Switch??
#641850
03/16/10 02:32 PM
03/16/10 02:32 PM
Posts: 992 Simi Valley, CA
MoparJ
Simi Valley, CA
After checking my ignition box (tried two different ones), swapping ballasts, swapping a coil, I still cannot get the Duster to stay lit. It will fire when I turn the key, but will die as soon as I let off. I thought this may have been ballast related at first, but evidently not.Wiring all looks ok.Ign
Is my next suspect the ignition switch?
2016 Ram 1500 Crew Cab: 5.7, 65RFE, 4.56 gears with locker, Hemifever tuned, AFE intake, 87mm throttle body, JBA headers, 3" Flowmaster exhaust, split to dual 2.5" exits. 13.57 best ET so far.
Searching for new A or B Body Project!
Re: Ignition Switch??
[Re: buildanother]
#641852
03/16/10 02:56 PM
03/16/10 02:56 PM
MoparJ
Simi Valley, CA
No. Previously, this was an intermittent issue, only occuring once in a while and the car would not try to start whatsoever for a few moments. After 5 or 10 minutes of trying, it would fire and run beautifully and start ok for the rest of the day.
This no run once the key is released symptom is new and now it is no longer starting, no matter how long I wait.
[Re: MoparJ]
#641853
03/16/10 03:04 PM
03/16/10 03:04 PM
RapidRobert
When in ign2 (start) the coil needs to be fed (full voltage bypassing the ballast) and the "point" of the ECU connector needs to be fed (4 pin ECU) plus another pin on a 5 pin (stock type) ECU. Take off the yellow "sol" wire from the starter relay to temporarily disable the starter (just to eliminate the noise/distraction and battery drain) and have a helper hold the key to "start" & you under the hood see if these 2 points (+) pri coil terminal & the "point" of pentastart connector) (3 if 5 pin) are getting fire. Sounds like classic ballast prob but not always and I had that recently on a stock 5 pin ECU truck and it was the ECU.
[Re: MoparJ]
#641854
03/16/10 03:07 PM
03/16/10 03:07 PM
Posts: 25,777 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Check the spade terminals on the brown IGN2 wire at the firewall disconnect.
[Re: RapidRobert]
#641855
03/16/10 03:08 PM
03/16/10 03:08 PM
MoparJ
Simi Valley, CA
The ignition box used is a Mopar Orange Box. FOr the past three years, I have used the original 4 prong style ballast, only utilizing the bottom two posts. No problems until about 3 months ago.
Starter relay was replaced about 4 months ago.
[Re: John_Kunkel]
#641856
03/16/10 03:10 PM
03/16/10 03:10 PM
MoparJ
Simi Valley, CA
What side of the bulkhead would that be on? I would search by colors, but the previous owner painted all of the firewall (including the wiring) black.
[Re: MoparJ]
#641857
03/16/10 03:17 PM
03/16/10 03:17 PM
John_Kunkel
Rio Linda, CA
The removeable connector on the firewall side is the usual source of problems, follow the brown wire in the blue/brown connector on one side of the ballast to the firewall connector.
[Re: MoparJ]
#641858
03/16/10 03:22 PM
03/16/10 03:22 PM
RapidRobert
The eng side of the bulkhead, the wire going to the brown wire on the ballast plug in. I have a stock well used 4 terminal ballast and it has 6 ohms on one side (which is way too high) and 1.4 ohms on the other and with both sides wired parallel I get 1.1 ohms which is perfect as the stock 2 terminal ballast supplied w the orange box kit is 1.25 ohms. See if the ballast has continuity and if it's getting fire
[Re: RapidRobert]
#641859
03/16/10 03:31 PM
03/16/10 03:31 PM
MoparJ
Simi Valley, CA
When you say you have both sides wired parallel, do you mean both bottom posts, or both lefts, or both rights?
[Re: MoparJ]
#641860
03/16/10 03:42 PM
03/16/10 03:42 PM
RapidRobert
To avoid any confusion, w the 4 terminal (double type) connector the blue loop connects one end and that is my input and on the other end I connect the brown and the green w red tracer wires together and that is my output. EDIT now I understand your Q,(with it mounted horizontle on the firewall) you'd connect the lefts (brn/grn w tracer) and the blue one on the right is already connected w the blue loop.
[Re: RapidRobert]
#641861
03/17/10 03:28 PM
03/17/10 03:28 PM
MoparJ
Simi Valley, CA
Well, I swapped to another ballast and vroom, it fired up. Ran for a while, then shut it off and restarted several times. No prob. Eventually, I got it to not start again, this time, not even when in the start position. Nothing. I did notice that when I would turn the key off, the ignition would spark, as the carb would backfire from it. Eventually, after sitting, the motor fired up and ran some more. I went out this morning before work and tried to start it again. No luck and this time, it is back to running in the start position, like a traditional ballast issue. What the hell? Looks like I will have to replace another ballast before I even begin to troubleshoot more.
I did notice that while running, the ballast was very warm.
[Re: MoparJ]
#641862
03/17/10 03:45 PM
03/17/10 03:45 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
It is normal for the ballast to get hot. This is why it is ceramic (to take the heat generated). Make sure the spade connectors fit tightly.
Do you have a test light or voltmeter?
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#641863
03/17/10 03:51 PM
03/17/10 03:51 PM
MoparJ
Simi Valley, CA
I do have a test light. I am going to look it over again. I am wondering if the ballast is wired wrong. I will have to check it out. The weird part of the issue is the spark of ignition that I get when i turn the key to the off position at times.
I have a feeling the fix is simple, but eluding me.
[Re: MoparJ]
#641864
03/17/10 04:28 PM
03/17/10 04:28 PM
Posts: 7,759 So Cal
HealthServices
So Cal
What application is this for?
two wire or 4 wire resistor?
points or electronic?
Allen
#641865
03/17/10 04:37 PM
03/17/10 04:37 PM
MoparJ
Simi Valley, CA
I am running an orange box with a 4 prong ballast. Only the bottom two posts of the ballast are being used. It has run like this for a long time.
[Re: MoparJ]
#641866
03/17/10 05:11 PM
03/17/10 05:11 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Sorry I did not read the previoust post.
I guess one question would be, Are you getting voltage in the run position at the coil?
Allen
#641867
03/17/10 05:49 PM
03/17/10 05:49 PM
MoparJ
Simi Valley, CA
I will check this once I get home from work in an hour.
If not volts, what should I look for?
If there is volts?
[Re: MoparJ]
#641868
03/17/10 07:56 PM
03/17/10 07:56 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Battery voltage at cranking
6-9 volts with just the key in the on position.
Allen
#641869
03/17/10 08:54 PM
03/17/10 08:54 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
is clear now, you are using a MP orange box now is happening even to Chromed boxes ( BTDT ) I hate to say and admit that from MP Since I would LOVE to keep a total Mopar car but, these are not being a very quality units latelly. I will be changing to FBO soon... As soon arrives to my hands
