4 speed removal #64165
05/26/08 07:37 PM
05/26/08 07:37 PM
ohio
B5 GTX Offline OP
B5 GTX  Offline OP
ohio
Getting ready to pull my 4 speed out and install a new one, and I wanted to know if I had to remove the factory H pipe or if it could be done leaving it in place? The car is a 69 GTX. In the past I think it was removed but looking closely at it I think it is possible to do without removing the H pipe.
Thanks for any input
Scott
Re: 4 speed removal [Re: B5 GTX] #64166
05/26/08 07:45 PM
05/26/08 07:45 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
If you can get the trans crossmember out of the way with the exhaust connected, and the tailshaft will clear the H-pipe, you're good to go.
Re: 4 speed removal [Re: B5 GTX] #64167
05/26/08 07:47 PM
05/26/08 07:47 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
It may be possible, but I have usually found that when I try to take short cuts, it take longer and is a whole lot more frustrating.
Careful, your character's showing!
