BB Rocker shafts #641429
03/15/10 10:34 PM
03/15/10 10:34 PM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
I have been tring to buy a set of BB rocker arm shafts from Hughes Engines for over a month and today they tell me that because the supply is so short they won't sell just the shafts, only with the rockers as a kit.
My question is who has the next best shafts, that can actually be purchased, to use with alum rocker with out needle bearings?
These are Mopar Performance rockers (made by Crane I think?)
Thanks, Brian
Re: BB Rocker shafts [Re: '72CudaRacer] #641430
03/15/10 10:41 PM
03/15/10 10:41 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Rather than the next best how about getting the best?
Rocker Arm Specialists
19841 Hirsch Ct.
Anderson, CA. 96007
(530) 378-1075
(530) 378-1177
rockers@rockerarms.com
Re: BB Rocker shafts [Re: 1_WILD_RT] #641431
03/15/10 10:56 PM
03/15/10 10:56 PM
Mooresburg, Tn
Mooresburg, Tn
19841 Hirsch Ct.
Anderson, CA. 96007
(530) 378-1075
(530) 378-1177
I'm listening Randy.
Re: BB Rocker shafts [Re: '72CudaRacer] #641432
03/15/10 11:57 PM
03/15/10 11:57 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Call & talk to them, they sell thick walled bannana grooved shafts with screw in plugs at the ends.. The Bannana grooves won't work with roller bearing but spread the oil providing better lubrication with bushed or metal to metal contact type rockers.. The screw in plugs can't pop out like typical core type plugs causing a loss of oil pressure & they can be removed for cleaning...
They also sell high quality steel rocker shaft hold downs...
Re: BB Rocker shafts [Re: '72CudaRacer] #641433
03/16/10 01:26 AM
03/16/10 01:26 AM
Boise
Moparteacher Offline
Boise
RAS shaft and bushed iron rockers all from RAS.
Shafts are available in std size also.
Re: BB Rocker shafts [Re: '72CudaRacer] #641434
03/16/10 08:11 AM
03/16/10 08:11 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
The last time I needed shafts RAS was out of stock and I had to get a set from Hughes. That was last year, so I can't say if RAS has them available individually now or not.
Re: BB Rocker shafts [Re: BradH] #641435
03/16/10 09:00 AM
03/16/10 09:00 AM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
Have you checked with Mazzolini?
951-787-8783
Re: BB Rocker shafts [Re: G_bob] #641436
03/16/10 09:38 AM
03/16/10 09:38 AM
Mo.
supercomp Offline
supercomp  Offline
Mo.
Re: BB Rocker shafts [Re: '72CudaRacer] #641437
03/16/10 04:47 PM
03/16/10 04:47 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Brian,
Check your PMs.
RIP Monte Smith
