stupid question, road lamp mounting position? #641313
03/15/10 09:35 PM
03/15/10 09:35 PM
indiana
mopar mike Offline OP
indiana
70 cuda, where does a road lamp switch mount? i bought a kit and i cannot find it in the electrical section in the fsm? a pic of it mounted on the dash would be great. also it says to put the light green wire in the tan connector, there are two? a q4, and a q4a? is there a difference? how do i tell which is which? thanks moparts
Re: stupid question, road lamp mounting position? [Re: mopar mike] #641314
03/16/10 09:38 AM
03/16/10 09:38 AM
indiana
indiana
nobody has road lamps on there cuda's??
Re: stupid question, road lamp mounting position? [Re: mopar mike] #641315
03/16/10 10:22 AM
03/16/10 10:22 AM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
Here's a pic of an Oct built Cuda-It's my business partners and is 95% original.
Re: stupid question, road lamp mounting position? [Re: Paul Jacobs] #641316
03/16/10 10:31 AM
03/16/10 10:31 AM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
Here's one from an AAR Cuda, original car from original owner.
Re: stupid question, road lamp mounting position? [Re: Paul Jacobs] #641317
03/16/10 03:53 PM
03/16/10 03:53 PM
Grand Rapids MI
N
N9671X2 Offline
N9671X2  Offline
N
Grand Rapids MI
Rally dash cars should be mounted onto the dash frame under neath the heater control bezel, attached to the metal frame, not the plastic. Dash frame, assuming correct year frame will have holes for it. Standard dash is on the switch panel, this panel would also be cut for it if it were an original roadlamp car, it not, you are going to probably have to get an exact location and modify.
Re: stupid question, road lamp mounting position? [Re: N9671X2] #641318
03/16/10 03:56 PM
03/16/10 03:56 PM
indiana
indiana
anyone have the correct location for a ralley dash location on the dash frame? measurments? thanks
Re: stupid question, road lamp mounting position? [Re: mopar mike] #641319
03/16/10 04:10 PM
03/16/10 04:10 PM
Green Lane, PA
sawdust Offline
sawdust  Offline
Green Lane, PA
Here you go
Re: stupid question, road lamp mounting position? [Re: sawdust] #641320
03/16/10 04:14 PM
03/16/10 04:14 PM
Green Lane, PA
sawdust Offline
sawdust  Offline
Green Lane, PA
Another, you may want to check the tech archives, as there was a nice post detailing wiring, relay location and hole locations.
Re: stupid question, road lamp mounting position? [Re: sawdust] #641321
03/16/10 04:43 PM
03/16/10 04:43 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
70 Cuda, Oct 6, 1969 SPD, Rallye Dash. Road lamp location.
Re: stupid question, road lamp mounting position? [Re: mopar mike] #641322
03/16/10 04:49 PM
03/16/10 04:49 PM
Denmark, Helsingor
AAR70 Offline
AAR70  Offline
Denmark, Helsingor
You can use both two tan connektors for the green road lamp wire .The tan connektors is acessery feeds.
Re: stupid question, road lamp mounting position? [Re: mopar mike] #641323
03/16/10 04:53 PM
03/16/10 04:53 PM
Snoopy Offline
Snoopy  Offline
Re: stupid question, road lamp mounting position? [Re: N9671X2] #641324
03/16/10 05:21 PM
03/16/10 05:21 PM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
That would be nice to assume, but I have documented 5 early (sept/oct) cars with the switch in the same location as I pictured. Hence the reason I made it a point to state it was an early car. This car is still original down to it's tires, belts, hoses, vapor seperator, battery cables, exhaust system etc and there was no hole in the dash for the switch-and it's on the broadcast sheet.
All these same early cars had argent Cuda tailpanel emblems too, as well as some other oddities. This I had to research thouroughly, because a car I was restoring was an early car, and had the switch in the "wrong" spot I thought.
I not here to argue of course, just stating what I have found in research. Whether you choose to accept it or not is up to you. I've learned to many things over the past 25 years to accept anything as gospel! cheers
Re: stupid question, road lamp mounting position? [Re: Paul Jacobs] #641325
03/16/10 05:29 PM
03/16/10 05:29 PM
Green Lane, PA
sawdust Offline
sawdust  Offline
Green Lane, PA
Paul,
Which plant were they from, I am guessing Hamtrack?
Re: stupid question, road lamp mounting position? [Re: sawdust] #641326
03/16/10 05:46 PM
03/16/10 05:46 PM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
Paul,
Yes your correct-also the only plant I found which had the black tar exposed in the trunk on the front parting seam-tacky for sure!
Re: stupid question, road lamp mounting position? [Re: Paul Jacobs] #641327
03/16/10 07:30 PM
03/16/10 07:30 PM
Wausau Wi
Convertcuda Offline
Convertcuda  Offline
Wausau Wi
Could someone post some pictures of all the correct hardware that hold the road lamp brackets to the bumper bracket. Maybe show head markings,length, washers size any little details. Maybe the location of the ground wire. Maybe some pics of where the road lamps front harness little s-clamps go. Thanks for any info. I am sure other would like to see this also. I have asked a ton of people and no ones seems to know.
Re: stupid question, road lamp mounting position? [Re: Convertcuda] #641328
03/17/10 03:58 PM
03/17/10 03:58 PM
Snoopy Offline
Snoopy  Offline
Engine bay wire routing.
Re: stupid question, road lamp mounting position? [Re: Snoopy] #641329
03/17/10 04:15 PM
03/17/10 04:15 PM
Snoopy Offline
Snoopy  Offline
Dash
Re: stupid question, road lamp mounting position? [Re: Snoopy] #641330
03/17/10 05:35 PM
03/17/10 05:35 PM
Snoopy Offline
Snoopy  Offline
Road Lamp Mounts
Re: stupid question, road lamp mounting position? [Re: Snoopy] #641331
03/17/10 05:36 PM
03/17/10 05:36 PM
Snoopy Offline
Snoopy  Offline
Ground
Re: stupid question, road lamp mounting position? [Re: Snoopy] #641332
03/17/10 05:40 PM
03/17/10 05:40 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Off topic but snoopy, you need to empty your pm box.
