.........I'm trying to figure out why my Temp guage isn't working. As in, does nothing. '73 Roadrunner, Rally gauges.......on 2nd sending unit.......fuel/oil pressure work fine, and the lead to the temp sender pulses........what should happen if I ground the test light to that, instead of a body ground? My engine ground is good........but I haven't actually tried hooking to the sender. Before I put the dash in, I checked the gauges with a small battery (from a post here) and they all worked. I didn't use any sealer, and the threads were clean on both it and the block. Maybe another bum unit? I want to fix it soon, it is the only thing left not working. Even the stupid seat belt buzzer works!
