What dipstick are you using with headers? #640853
03/15/10 01:21 PM
03/15/10 01:21 PM
Manitoba, Canada
DaytonaTurbo Offline OP
Manitoba, Canada
I tried using my stock dipstick with a set of headers, but it looks kinda dumb because it's got that mounting tab with nothing to mount it to, and my dipstick needs something to bolt to to keep it from flopping around. What are you guys using with headers? I was thinking about making my own clamp out of sheet metal that would wrap around a header tube. Any other ideas?
Re: What dipstick are you using with headers? [Re: DaytonaTurbo] #640854
03/15/10 01:30 PM
03/15/10 01:30 PM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
I have a '73 Charger with a BB stroker and headers so I went through the same thing. I used a Milodan flexible dipstick (made out of stainless steel braided line material). IIRC, I bent the 90 degree bracket it had on it flat and attached another one I made out of aluminum (to extend it)and took it to a valve cover bolt.
I am sure there is probably a better way to do this but this worked for me.
Re: What dipstick are you using with headers? [Re: cjskotni] #640855
03/15/10 04:05 PM
03/15/10 04:05 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Re: What dipstick are you using with headers? [Re: Lefty] #640856
03/15/10 04:35 PM
03/15/10 04:35 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
How about a bracket that secures the tube to the motor mount area or a header bolt?
On my racecar I use a sight tube on the pan itself, which we calibrated one quart at a time. It's basically a tygon tube between two 90-degree fittings, tall enough to have a range of several quarts.
Re: What dipstick are you using with headers? [Re: Lefty] #640857
03/15/10 07:56 PM
03/15/10 07:56 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Any pics of one installed with headers? That tab looks like it bolts right to the header and will be hot to handle...I need one and have to order ASAP and the chrome ones don't work well with headers and that are to big after the chroming process to fit in the hole...
Re: What dipstick are you using with headers? [Re: QuickBpBp] #640858
03/15/10 08:36 PM
03/15/10 08:36 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
Milodon mounted to header stud (BB A-body).
Re: What dipstick are you using with headers? [Re: 70Duster440] #640859
03/15/10 08:44 PM
03/15/10 08:44 PM
New Kent, Va.
bobbyb Offline
bobbyb  Offline
New Kent, Va.
Is it possible to cut the tab off and tack it on with a mig welder in another location? Just a thought, if you have a welder.
2004 Dodge Rumble Bee 5.7 Hemi
1969 Plymouth Roadrunner
Re: What dipstick are you using with headers? [Re: bobbyb] #640860
03/15/10 09:51 PM
03/15/10 09:51 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
Just get a piece of 3/8 steel fuel line and make your own. The OD is slightly large but easy enough to get it to fit w/emery cloth. Weld a tab to fit whatever works best for you ( I used a valve cover bolt), check the oil level and re-mark stick if necessary. Cost about $2 and maybe 1/2 hour of your time.
Re: What dipstick are you using with headers? [Re: Bill MeLater] #640861
03/15/10 11:12 PM
03/15/10 11:12 PM
IN
ahy Offline
ahy  Offline
IN
I tried 3 setups. First was a Mancini "outside the headers" design. It worked great on the engine stand but wants to take up the same space as the power steering in the car. Next was the flexible dipstick. It seemed to wipe the oil off when pulled around turns and I couldn't read it.
Finally I ordered a stock chrome re-pop stick. it fits between the header flange and tube. The stabilizing tab bolts to the engine mounting bracket bolt. It works fine. Its just a PITA to pull it if the headers need pulled. The engine mount bolt is not easy to get at. And I did need to sand down the end to get it to fit the block.
Re: What dipstick are you using with headers? [Re: ahy] #640862
03/15/10 11:24 PM
03/15/10 11:24 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
I don't want o go through with that chrome one again it fought me and when I was done the stick was hard to get in and out. I swear it was triple plated!!!
Did you have to do anything to the Mancini race dipstick to get it to fit in the block?
Also Thanks for the pics 70 Duster...Mine is a B-body and has spool type mounts with manual steering & Hooker headers. I think I can get that to work like you did...
Re: What dipstick are you using with headers? [Re: QuickBpBp] #640863
03/16/10 01:16 AM
03/16/10 01:16 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I actually got the chrome one to work good for me. I had worked the dipstick hole when I did my block so the chrome tube went in without much trouble. Then a very small tack weld as I ran it on the outside of the headers. It has worked fine for over 3 years. Ron
Re: What dipstick are you using with headers? [Re: 383man] #640864
03/16/10 08:52 AM
03/16/10 08:52 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Mine looks similar to Rons. It is a trans dapt. It has the mounting tab just like the stock dipstick that mounts to the engine mount bolt. I had to grind the end that slid into the block a little since it was too big but I'd rather have it too tight than too loose.
Re: What dipstick are you using with headers? [Re: Lefty] #640865
03/16/10 12:48 PM
03/16/10 12:48 PM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
I use the Milodon also.
http://www.summitracing.com/parts/MIL-22070/
Same here
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: What dipstick are you using with headers? [Re: BloFish] #640866
03/16/10 01:47 PM
03/16/10 01:47 PM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
Same here
Me three.
BB 68 Dart. Used one of the header bolts to attach it.
Here's a pic
codfish
Re: What dipstick are you using with headers? [Re: codfish] #640867
03/16/10 02:00 PM
03/16/10 02:00 PM
Winnipeg, MB, Canada
71Plym Offline
71Plym  Offline
I use a dipstick from Mancini. If I recall correctly, it attaches to the motor mount bolt.
Re: What dipstick are you using with headers? [Re: QuickBpBp] #640868
03/16/10 06:44 PM
03/16/10 06:44 PM
IN
ahy Offline
ahy  Offline
IN
As I remember the Mancini racing dipstick fit the block with no adjustment required. It just didn't fit my engine compartment with PS.
Re: What dipstick are you using with headers? [Re: ahy] #640869
03/16/10 08:24 PM
03/16/10 08:24 PM
Mooresburg, Tn
'72CudaRacer Offline
Happy Birthday '72CudaRacer  Offline
Mooresburg, Tn
I used a stock dipstick tube, cut the tab off and attached the tube to the header tube with a stainless steel hose clamp. Mines a race only car, you my not want do this to a street car.
Re: What dipstick are you using with headers? [Re: ahy] #640870
03/16/10 09:36 PM
03/16/10 09:36 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
The chrome one is what i'm useing. Fit perfect with headers. I painted it engine color to be stock looking.
Re: What dipstick are you using with headers? [Re: Dougsmopars] #640871
03/16/10 11:34 PM
03/16/10 11:34 PM
arizona, usa
lokalik Offline
lokalik  Offline
arizona, usa
lokar.
Re: What dipstick are you using with headers? [Re: BloFish] #640872
03/28/10 12:17 PM
03/28/10 12:17 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Same here
Well I used this one and had to unbolt the motor mount and jack the motor up to install it. Big block with manual steering,spool mounts and Hooker Super comps. I then went to put the dipstick in and it is extremely difficult to get in and out and stops right where the braided tube goes into the collar. I have to spin it to go past that point. Also that collar is why I had to pull the mount to get it in.....
