BB valve train set up question #640726
03/15/10 06:42 AM
03/15/10 06:42 AM
Löffingen, Germany
The_Mean_Machine Offline OP
Löffingen, Germany
I’m in the process off setting up the valve train on a 383 / 496 stroker engine with Indy 440ez heads, roller cam, Comp Cam hydr. Retrofit lifters, Hughes Aluminum Roller Rockers with hold down studs and billed hold downs.
Hughes recommends to set up the valve train in a way that the push rod and the rocker adjusting screw are in one common line @ 50% of the valve lift.
In order to achieve this I would need to raise the rocker shaft approx. 0,060”. This would require some special shims (common radii inside and outside, see pic:)
and are quite tricky to manufacture.
The question I have: is it really necessary to go through this effort or in other words, what is the technical background making it important to have this common line? Generally I would say in a perfect world the forces on the adjusting screw are minimized and therefor wear on the valve train is minimized. But since this is more a theoretical value (50% of valve lift is passed 2 times per opening cycle) do I really gain a lot by adjusting it?
Btw, the attached picture shows the angle @ 50% valve lift without any shims…
and here is the wipe pattern without shims (the inboard mark comes from fooling around with the rockers :)
Re: BB valve train set up question [Re: The_Mean_Machine] #640727
03/15/10 07:09 AM
03/15/10 07:09 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
not sure what's up with all that math but you can shim up your shafts. I had to do it on an old 383 I had that was decked and heads were milled. Any spped shop should have the shims you need.
Coming soon!!!!
Re: BB valve train set up question [Re: Mr.Yuck] #640728
03/15/10 07:18 AM
03/15/10 07:18 AM
Löffingen, Germany
Löffingen, Germany
the shims available are just pieces of bend sheet metal with a constand material thickness. Such shims will leave a gap in the lowest point of the shaft saddle and I am afraid of loosing oil pressure were the rocker shafts are feed. Btw. Dimensions in the sketch are metric...
Re: BB valve train set up question [Re: The_Mean_Machine] #640729
03/15/10 08:20 AM
03/15/10 08:20 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I dunno what to tell you boss. I ran them for 2 years w/o a problem. This was a 383 that I shifted at 6800 and ran the snot out of it. It had plenty of oil pressure.
Coming soon!!!!
Re: BB valve train set up question [Re: Mr.Yuck] #640730
03/15/10 11:42 AM
03/15/10 11:42 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I thought the rocker shims were made out of a bit softer material to help them conform to the shaft shape? Even if not, many people have run them without issue, but .060 would be a lot of shimming.
Re: BB valve train set up question [Re: DaytonaTurbo] #640731
03/15/10 11:48 AM
03/15/10 11:48 AM
Aurora Colorado
BELVEDERE67 Offline
mopar addict
BELVEDERE67  Offline
mopar addict
Aurora Colorado
When looking at the roller travel across the valve tip, I don't really think you need it.
Re: BB valve train set up question [Re: BELVEDERE67] #640732
03/15/10 11:58 AM
03/15/10 11:58 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
It's wiping in the middle of the valve in it's travel.
Re: BB valve train set up question [Re: roadhazard] #640733
03/15/10 02:44 PM
03/15/10 02:44 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
That and the shims are NOT a complicated deal. Ten, one inch sqare pieces of aluminum with a hole in the middle.
Re: BB valve train set up question [Re: RemCharger] #640734
03/15/10 02:48 PM
03/15/10 02:48 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
While I agree the pattern looks good & I would run it as it is the issue with rocker shims that most seem to not think is any big deal can be.. I've seen enough rocker pads split from using flat shims to say you should use conoured shims..
Re: BB valve train set up question [Re: 1_WILD_RT] #640735
03/15/10 03:34 PM
03/15/10 03:34 PM
You are overthinking it. Just get some soft copper flat washers of the right thickness with the bolt hole dia correct (larger dia for the pedestal that feeds the shaft) that will easily conform to the saddles, mock them up & get the straight line @50% then check the wipe pattern. The wipe pattern is more important than the straight line but get the straight line 1st and If you are feeding the shafts up from the cam I would consider oiling in horizontally from the back of the heads then angling up to the rear pedestal and restricting the crank to cam feed passages w setscrews w a 1/16" hole drilled in each one which is plenty of lube for the cam bearings/journals but one problem at a time.
Re: BB valve train set up question [Re: RapidRobert] #640736
03/15/10 05:14 PM
03/15/10 05:14 PM
Löffingen, Germany
Löffingen, Germany
Thanks for the feedback so far.
So the wipe pattern is more important than the straight line between PR and Rocker Adjusting Screw?
Can someone adjucate me why?
And honestly, I do not believe the 'whatever soft material the of the shelf shims are made of' can be compressed this much to really gap 0,016" at the bottom of the rocker saddle and provide sufficend distributed clamping force...
But maybe I am realy pushing it too far
Frank
Re: BB valve train set up question [Re: The_Mean_Machine] #640737
03/15/10 05:21 PM
03/15/10 05:21 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Frank
Its just an old plymouth.
You will be fine without doing anything, just put it together.
Re: BB valve train set up question [Re: RemCharger] #640738
03/15/10 05:25 PM
03/15/10 05:25 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Actually looking back at your pictures,,, do you have enough rocker to retainer clearance?
What kind of rockers are they and whats the cam specs?.....
Re: BB valve train set up question [Re: The_Mean_Machine] #640739
03/15/10 05:35 PM
03/15/10 05:35 PM
(1)Yes according to Dave Hughes who has forgotten more info than I will ever know. (2) I do not have the ability to edumacate any one (3) If you need to raise the shaft ie .060" to get the pushrod angle straight then a shim(5 of em) or soft copper washers of that thickness are what you would need. PS get it perfect and you will (A) sleep better at night) (2) have an edge on your opponents (3) It will train your mind to demand perfection (or near perfection within reason depending on the app) which is why Mopar is #1. One of the Nascar teams wants the rivet heads on outer body panels to have the slots all parallel to each other .(keeps you in the mindset of seeking perfection in every subsystem and it all adds up in the end.)
Re: BB valve train set up question [Re: RemCharger] #640740
03/15/10 05:45 PM
03/15/10 05:45 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I'm curious why Hughes would borther with that... You can't adjust either location (lifter or rocker screw placement). You can minimize the sideways push on the screw by having minimum threads exposed (the longest pushrod you can for your assembly...) but that's it. What I learned is you want the roller on the exhaust flange side of the valve tip at exactly 1/2 lift. The arc the roller traces places it furthest from the shaft centerline at mid lift if the geometry is correct. The sweep looks a little narrow to me but if the cam's moderate that would be why. It placed well, providing the tip starts on the inboard side on the base circle, then moves accross the tip to the exhaust flange side at mid lift, then back to the inboard side at max lift. Needing correction is the result of the valve job being off. I'm hoping the heads were fixed rather than out of the box. I would not run shims if this needs to go higher in the rpm range (above6500) on a regular basis. Shims do not allow for the best support of the shaft.
Re: BB valve train set up question [Re: moper] #640741
03/15/10 06:17 PM
03/15/10 06:17 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Actually I might be more concerned with the valve locks
Are those stamped locks or machined? If they are not machined I'd toss them
Also I would machine and put rockershaft stands on there before I'd use a shim. another
Re: BB valve train set up question [Re: The_Mean_Machine] #640742
03/15/10 06:57 PM
03/15/10 06:57 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
My opinion is you are okay with what you have. How and where did you measure your 50% lift?
Mancini use to have tapered shims and you might check with RAS.
Re: BB valve train set up question [Re: RemCharger] #640743
03/17/10 07:57 AM
03/17/10 07:57 AM
Löffingen, Germany
Löffingen, Germany
this is the cam, installed @104°
Rocker to retainer clearance is fine...
Re: BB valve train set up question [Re: roadhazard] #640744
03/17/10 07:59 AM
03/17/10 07:59 AM
Löffingen, Germany
Löffingen, Germany
The locks are the ones supplied with the heads from Indy. I would say they are stamped, but I am not 100% positive.
Whats the failure mode with stamped locks?
Re: BB valve train set up question [Re: The_Mean_Machine] #640745
03/17/10 11:07 AM
03/17/10 11:07 AM
AndyF Offline
AndyF  Offline
Wear pattern looks fine to me for the intended use. I wouldn't use shims.
