the 8 shorter springs would have had the rotators on the top to let the exhast valve spin as it opened/closed
if you installed them,I would think they would work fine..but it will make the retainer to valve guide clearance less
what you need to do is go back and swap all the rotators out for 8 more intake retainers for a total of 16 intake retainers
this will make all the springs same height and give the best clerance on the valve guides
let me know if you need 8 intake retainers,I have a box full of extras...you can have 8 of them
