Brake fluid DOT 3 vs DOT 5 #640574
03/14/10 11:09 PM
03/14/10 11:09 PM
SE PA.
Q
QuickBpBp Offline OP
Q
SE PA.
I'm doing my brake system and bought dot 5 to replace the dot 3 since it doesn't eat paint...Many hours in painting the engine compartment I don't want to risk it...The "parts counter guy" said there is NO way he would ever consider it that I will have a spongy pedal and poor braking but I was told by some no difference will be noticed just don't mix it with other types of brake fluid which I knew...Anything else to consider. It's a street/strip car and ran almost 130mph,I don't want poor braking...Thanks in advance
Re: Brake fluid DOT 3 vs DOT 5 [Re: QuickBpBp] #640575
03/14/10 11:16 PM
03/14/10 11:16 PM
IN
ahy Offline
ahy  Offline
IN
Wish I had gone the DOT 5 silicon route. A stubborn leak at the MC connections has messed up my engine bay paint with conventional DOT4.
From what I've heard, DOT5 is a little slower bleeding due to viscosity. Bleed, wait a few hours for the bubbles to combine, bleed again. Once bled, it works fine.
Re: Brake fluid DOT 3 vs DOT 5 [Re: ahy] #640576
03/14/10 11:24 PM
03/14/10 11:24 PM
SE PA.
Q
Q
SE PA.
Thanks for the info and sorry for your engine compartment getting messed-up...
It's amazing how much time it takes to strip,blast,repair,sand and paint just an engine compartment...Alot of cracked rough finger tips when done and I know I would be if I ended up seeing it get messed-up.
Re: Brake fluid DOT 3 vs DOT 5 [Re: QuickBpBp] #640577
03/14/10 11:24 PM
03/14/10 11:24 PM
Ft.Myers,Florida
Hemiruss Offline
Hemiruss  Offline
Ft.Myers,Florida
DOT 5 is the only way to go,just did a couple customers cars and it's worth it.It doesn't ruin your paint and the higher temp.benifits are well worth it,it's nice to convert over because it's a different color and it's thicker....no pedal difference and the benifits are definitely great.
If you need the inside spec.and tech.info.get ahold of Mastershake340 on here...he's a brake GURU....
Re: Brake fluid DOT 3 vs DOT 5 [Re: ahy] #640578
03/14/10 11:40 PM
03/14/10 11:40 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
the reason most people have trouble with DOT 5 brake fluid is because it retains AIR like DOT 3 does water. if you use DOT 5 leave a open bottle out in the sun for at least 1/2 hour to boil out the air that forms inside the bottles when it's shipped and handled. this is the reason it's sold in black bottles. or you can place a open bottle in HOT watter, about 200*, for about 20 min. when doing this you can watch the air bubble release from the fluid. some people tell me that it's boiling. that's not happening it's just the air releasing from the fluid. i use this method as much as possible.
when you install it in your car. suck out the old fluid in the master with a turkey baster or something like that, i use a old animal syringe that's rather large.
them pour in the new stuff and then bleed out the new fluid thru the lines. you can easily see the new stuff because it's purple.
use caution when bleeding the brakes. so SLOWLEY pump the petal so you don't form bubbles in the master.
also DO NOT ATTEMPT TO FLUSH the system with anything, the most often one i hear is alcohol. this will create problems when bleeding the brakes because it will compress more than brake fluid before getting hard and give you a spongy petal.
DOT 5 fluid will not gel when it's mixed with DOT 3. it won't mix with it eather. but they will not react to each other. when you mix them in a jar and shake they will look mixed but after time they will just separate.
hope this info helps. i have been using DOT 5, silicone, for over 10 years without any problems.
perception is 90% of reality
Re: Brake fluid DOT 3 vs DOT 5 [Re: Mr T2U] #640579
03/15/10 12:30 AM
03/15/10 12:30 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
That's funny because our DOT 5 is shipped in WHITE 1 gallon jugs.We use it everyday in the vehicles at work.No problems bleeding it,nor does it give a spongy pedal.
Nautilus Racing-
Re: Brake fluid DOT 3 vs DOT 5 [Re: Chris2581] #640580
03/15/10 12:32 AM
03/15/10 12:32 AM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
with this new knowledge of air bubbles in the can, I may try it. I was always afraid of the spongy pedal that I always hear about.
Re: Brake fluid DOT 3 vs DOT 5 [Re: pishta] #640581
03/15/10 12:40 AM
03/15/10 12:40 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Everyone I know that plays with old cars uses the DOT5 Silicone brake fluid and has for most of 20 years.
Never had any problems with a spongy pedal or fade.
Re: Brake fluid DOT 3 vs DOT 5 [Re: QuickBpBp] #640582
03/15/10 12:53 AM
03/15/10 12:53 AM
El Cerrito, by San Francisco
last426 Offline
last426  Offline
My, my, my, what an enlightened view of DOT 5. Eight years ago most would be hating, now most are in favor. New and better things take a while I guess. I use it cause I hate the idea of paint remover coursing through 30 year old veins. Never a problem. Kim
Re: Brake fluid DOT 3 vs DOT 5 [Re: last426] #640583
03/15/10 08:18 AM
03/15/10 08:18 AM
London, England
Gavin Offline
Gavin  Offline
London, England
One other point - because it does not absorb moisture, any that does get into your system may end up pooling somewhere - for example at your caliper etc. So there is a risk of localised rusting. It also costs a bunch.
I got 5.1 - mineral with equivalent hi-temp properties as 5.0, but much cheaper, easy to bleed, no risk of pooling etc. BUT - if it gets on my paint I may wish I went with 5.0....
Re: Brake fluid DOT 3 vs DOT 5 [Re: last426] #640584
03/15/10 08:36 AM
03/15/10 08:36 AM
Mr T2U Offline
Mr T2U  Offline
the only reason i said it's in black bottles is because that's the only way i have ever seen it. i only buy it 1 quart at a time. i am sure somewhere it's available in white quart and pint containers also.
the air bubbles problem is the reason why it's not recommended in use on anti lock braking systems.
if anyone has any doubts about my statements do a simple test.
shake up some DOT 5 fluid. let it sit on the bench for several hours. now pour some, save some for later, into a container that's in boiling or very hot water. get the fluid up to around 200*. you will see air bubbles being released when it sits in the hot water. now let the extra fluid sit for a few weeks and do the water trick again. it will do the same thing as the freshly shaken fluid. i am sure some air will work it's way out by itself but there will be lots of air trapped into the system.
DOT 5's ability of retaining air is why you hear so many comments about how it will give you a spongy brake pedal.
one other thing to keep in mind it can allow water to stay in your brake system. over time the water in the fluid can mess your brake system up from the inside out. so every 4 or 5 years change the fluid. it also can get shaken up inside your master cylinder creating air bubbles. so if you brakes pedal starts to get soft. change the fluid and the hard pedal should return.
Re: Brake fluid DOT 3 vs DOT 5 [Re: Mr T2U] #640585
03/15/10 09:52 AM
03/15/10 09:52 AM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
DOT 5 is hydroscopic, it will absorb water! I agree with Mr T2U and change every few years, esp w/ steel lines.
Re: Brake fluid DOT 3 vs DOT 5 [Re: Bull1tt] #640586
03/15/10 01:01 PM
03/15/10 01:01 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
no, DOT 5 silicone is not hyGROscopic.
http://en.wikipedia.org/wiki/Hygroscopy
That's one of its major benefits!
The reason there still may be a water problem is that the water does NOT mix with the DOT 5, and it settles at the lowest point in the system, which is usually an expensive caliper.
Re: Brake fluid DOT 3 vs DOT 5 [Re: DrCharles] #640587
03/15/10 01:31 PM
03/15/10 01:31 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
dot 5 here,everything new,bleed by myself,just took longer,as i first did gravity,then slowly pumped pedal with master cap off,best pedal i've ever had,manual front disc rear drum
Re: Brake fluid DOT 3 vs DOT 5 [Re: QuickBpBp] #640588
03/15/10 09:00 PM
03/15/10 09:00 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
..this discussion will never stop.
use Dot 3 with care and you will be fine
take the lady out with the money you save
Re: Brake fluid DOT 3 vs DOT 5 [Re: can.al] #640589
03/15/10 11:42 PM
03/15/10 11:42 PM
SE PA.
Q
Q
SE PA.
Already got Dot 5 and while I know I would be careful a leak is something I have no control over..
Thanks for all the info guys...
Oh and it doesn't matter what I spend I still have to take my 2 boys and the "lady" out..
