Is my 6 bbl engine block original? #640276
03/14/10 08:37 PM
03/14/10 08:37 PM
BLACKHEMIRR Offline OP
My 1970 440-6 block has the entire vin stamped on the pad (not just the last 8 digits), and it's a January 69 cast block with a September 69 build date for the car. Does that all seem right? It's a Lynch road car if it would make a difference. Thanks
Re: Is my 6 bbl engine block original? [Re: BLACKHEMIRR] #640277
03/14/10 08:55 PM
03/14/10 08:55 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
I would say NO.
Full VIN# stampings were used during the first half of the 1969 model year.
I have NEVER seen an authentic '70 model year engine with the full VIN#.
What is the engine assembly date off of the top pad?
Re: Is my 6 bbl engine block original? [Re: 6bblgt] #640278
03/14/10 08:59 PM
03/14/10 08:59 PM
I'll have to check that. I know it does have F 440 HP stamped on it, but I guess that doesn't mean much.
Re: Is my 6 bbl engine block original? [Re: BLACKHEMIRR] #640279
03/15/10 08:28 AM
03/15/10 08:28 AM
The front pad still has the original milling machine marks on it and has the following info:
F 440
11 12HP2
I expected to see three numbers, month/day/sequence number, so I'm not sure how to decode the build date. Does anyone have any thoughts? Like I said, it has a Jan '69 casting date on it and the car has a Sept '69 build date on the fender tag.
Re: Is my 6 bbl engine block original? [Re: BLACKHEMIRR] #640280
03/15/10 10:45 AM
03/15/10 10:45 AM
SF Bay Area, CA
charger440sixpak Offline
SF Bay Area, CA
F 440
11 12HP2
F 440 - 1970 440 CI block
11 12 - Assembly date of Nov 12, 1969
HP2 - High Performance build, second shift
Re: Is my 6 bbl engine block original? [Re: charger440sixpak] #640281
03/15/10 11:33 AM
03/15/10 11:33 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
November assembly date vs a September SPD?
I would also say "NO" based on the full VIN stamping (just as Dan said). Beyond that SPD's were just scheduled dates, so it's POSSIBLE that your car was built 2 months later than your SPD shows, but it's out of the realm of normal based on what I've seen. I'd do some more digging on that one for sure, get some REALLY clean close up shots of all of the engines stampings as well as those on the transmission and post them here (with the paint cleanly removed from all areas with numbers).
Re: Is my 6 bbl engine block original? [Re: 6bblgt] #640282
03/15/10 02:43 PM
03/15/10 02:43 PM
Pittsburgh, PA
Deuces-Wild Offline
Deuces-Wild  Offline
Pittsburgh, PA
I would say NO.
Only last 8 digits on a 70...
Re: Is my 6 bbl engine block original? [Re: Deuces-Wild] #640283
03/15/10 02:51 PM
03/15/10 02:51 PM
Thanks everyone. I agree with you, it doesn't look good. One more thing, the milling machine marks aren't visible any more on the vin pad. It looks like it was sanded. It looks completely different from every other block I have. I appreciate your help.
Re: Is my 6 bbl engine block original? [Re: BLACKHEMIRR] #640284
03/15/10 03:20 PM
03/15/10 03:20 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Can you post any pictures?
Admiration For Multiple Carburetor Vehicles...
