Why does my cooling system do that??? #639946
03/14/10 05:06 PM
03/14/10 05:06 PM
Central Illinois
mity225 Offline OP
mity225  Offline OP
Central Illinois
This problem seems pretty odd to me. 1986 Dodge D100 truck, manual transmission (OD), with high milage continually fills the overflow bottle with coolant.
This thing starts EVERY time I hit the key. Runs so good there can't be anything seriously wrong with it. (OK, once you get past the blue fog on startup, but I'll get those valve stems seals in there someday..) It doesn't run hot, but every time I look, the radiator is down there and the coolant bottle is full! I recycle it to the radiator and away I go again for a month.
I originally thought it was blow-by (rings), but then I thought how would that put positive pressure in the coolant? Blow-by would show on the breather, but not this one.
I'm thinking head gasket cross-over into the coolant. If it's not that, cracked head maybe? It's been hot once or twice...
What else could it be?
JK mity225@mchsi.com
Always looking for my next project!
Re: Why does my cooling system do that??? [Re: mity225] #639947
03/14/10 05:14 PM
03/14/10 05:14 PM
hobbs, new mexico
SixDRacing Offline
SixDRacing  Offline
hobbs, new mexico
replace the radiator cap. use a closded system cap without a pressure relief lever.
Re: Why does my cooling system do that??? [Re: SixDRacing] #639948
03/14/10 05:24 PM
03/14/10 05:24 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
In a closed system with a properly configured coolant recovery bottle [the hose dumping at the bottom of the bottle], it is normal for some coolant to move from the radiator into the overflow bottle as it expands with heat. What might be at play here is that your radiator cap has failed or is of the wrong design. A lever-less radiator cap designed for this type of system will have a small vacuum relief valve in the center of the seat. Once the expanded coolant cools [and contracts], some amount of coolant will be drawn back into the radiator from the overflow bottle.
Down to just a blue car now.
Re: Why does my cooling system do that??? [Re: 68HemiB] #639949
03/14/10 08:27 PM
03/14/10 08:27 PM
scratchnfotraction Offline
good rubber on the cab
16lbs rating
little dingy valve thing on the bottom
so when it cools off it will suck water back in rad from catch tank
check the hose from rad to bottle also,thin weak hose will suck flat and not recover h2o
