3spd wiper is a 1spd wiper, whats wrong? #639551
03/14/10 11:35 AM
03/14/10 11:35 AM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
I finally got to test my electrical system in my 69RR that I've been restoring for a few years. My 3spd wiper motor only goes 1 slow spd. I also got slightly shocked through the switch once . Is it the switch, grounds, or the motor (which I doubt cause it came from Jules). Any help would be greatly appreciated, as my electrical knowledge is not so good.
Thanks,
Brent
Re: 3spd wiper is a 1spd wiper, whats wrong? [Re: NV69B7RR] #639552
03/14/10 11:58 AM
03/14/10 11:58 AM
if it runs at the same slowest speed in all 3 switch positions I'd suspect the switch. With your VOM I'd check check voltages on the output side with the sw in all 3 positions (should be different on each setting)
Re: 3spd wiper is a 1spd wiper, whats wrong? [Re: RapidRobert] #639553
03/14/10 12:03 PM
03/14/10 12:03 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Make sure the switch is grounded.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 3spd wiper is a 1spd wiper, whats wrong? [Re: moparmarks] #639554
03/14/10 09:22 PM
03/14/10 09:22 PM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
Check that you have good contacts at the bulkhead connectors also.
Motor must be well grounded as well as the switch.
Jules
