3spd wiper is a 1spd wiper, whats wrong?
#639551
03/14/10 11:35 AM
03/14/10 11:35 AM
Posts: 6,005 Reno, Nevada
NV69B7RR
Reno, Nevada
I finally got to test my electrical system in my 69RR that I've been restoring for a few years. My 3spd wiper motor only goes 1 slow spd. I also got slightly shocked through the switch once . Is it the switch, grounds, or the motor (which I doubt cause it came from Jules). Any help would be greatly appreciated, as my electrical knowledge is not so good. Thanks, Brent
Re: 3spd wiper is a 1spd wiper, whats wrong?
[Re: NV69B7RR]
#639552
03/14/10 11:58 AM
03/14/10 11:58 AM
RapidRobert
if it runs at the same slowest speed in all 3 switch positions I'd suspect the switch. With your VOM I'd check check voltages on the output side with the sw in all 3 positions (should be different on each setting)
[Re: RapidRobert]
#639553
03/14/10 12:03 PM
03/14/10 12:03 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
Make sure the switch is grounded.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
