DLI Rocker Arm Ratio #639484
03/14/10 07:02 AM
03/14/10 07:02 AM
MI, Lapeer
maximus Offline OP
maximus  Offline OP
MI, Lapeer
Picked up a set of Dick Landy Hemi roller rockers in excellent condition. Does anybody know the ratio for the intake and exhaust made by Landy? Thanks
Re: DLI Rocker Arm Ratio [Re: maximus] #639485
03/14/10 09:05 PM
03/14/10 09:05 PM
CA.
RAY1969CARS Offline
RAY1969CARS  Offline
CA.
ya i made them for 5 years i would make 150 1.5 and 50 1.6 but there are no markings on the rockers only on the o.g. box you have to measure but you can see it in the bore it will be closer to the roller
Re: DLI Rocker Arm Ratio [Re: RAY1969CARS] #639486
03/14/10 09:07 PM
03/14/10 09:07 PM
CA.
RAY1969CARS Offline
RAY1969CARS  Offline
CA.
next
Re: DLI Rocker Arm Ratio [Re: RAY1969CARS] #639487
03/17/10 01:05 PM
03/17/10 01:05 PM
MI, Lapeer
maximus Offline OP
maximus  Offline OP
MI, Lapeer
Thanks for the info. So what you are saying is the rocker shaft bore is closer to the roller on the 1.5 ratio? Is this correct? Is this the same for the intake and exhaust to see this offset in the rockers?
Re: DLI Rocker Arm Ratio [Re: maximus] #639488
03/17/10 03:18 PM
03/17/10 03:18 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
My DLI Roller rockers are stock ratio...IIRC like 1.52 and 1.55 or something like that...
And the Geometry was pretty close too.
Re: DLI Rocker Arm Ratio [Re: maximus] #639489
03/17/10 07:20 PM
03/17/10 07:20 PM
CA.
RAY1969CARS Offline
RAY1969CARS  Offline
CA.
NO THE BORE OR BUSHING IS OFF SET CLOSER ON THE 1.6 THE 1.5 ARE IN THE CENTER OF THE CASTINGS
