Media-blasting...
#639398
03/14/10 01:09 AM
03/14/10 01:09 AM
Posts: 1,967 ID/MT
Cheeto
ID/MT
Do it myself or farm it out? I plan to completely dis-assemble the two trucks I'm working on to get all the rusty spots cleaned up. Should I buy a Harbor Freight blaster and do this one panel at a time over a large tarp or would it be cheaper in the long run to let the pros handle it? What media should I use? Anybody have home-made blasting booth (not cabinets) pics/tips?
Cheeto It's not perfect. It's not correct. It's not yours!
Re: Media-blasting...
[Re: chrisf]
#639401
03/15/10 11:22 AM
03/15/10 11:22 AM
Posts: 4,046 Minnesota
72blubird
Minnesota
I agree with the others have it done.
What was I thinking....
[Re: 4bbl]
#639403
03/16/10 11:27 PM
03/16/10 11:27 PM
Posts: 1,757 levittown pa
fstfish66
levittown pa
never used media,,,but helped a friend sand blast a 55 truck frame,in a drive way in a neighborhood full of houses,,,small comperssor,,5 horse single stange pump,,canister type sand tank,,,
made a booth out of the blue tarps you buy at the home stores,,,when the tank was empty,we swept up the sane,,sifted it thru a fine screen in to a bucket,,,then re-used it,, was a little messy,,but not bad,,,but that was a frame not sheet metal,,,if you dont know what your doing,,and your body is sorta straight,,you can really mess things up,,,,but to say you done it your self,says a lot also,,,
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
[Re: fstfish66]
#639404
03/16/10 11:30 PM
03/16/10 11:30 PM
Posts: 163 Iowa,US
4bbl
Iowa,US
"done it myself" is good brag!
4bbl
If you can't hear it coming what's the point.......
[Re: 4bbl]
#639405
03/17/10 08:47 AM
03/17/10 08:47 AM
Posts: 773 Crofton, Ky.
rattler
Crofton, Ky.
I too was wanting to blast my 57 project. I think i will blast the frame first and see how that go's.Since i am doing this at the farm, nieghbors are not an issue. (1/8 mile in either direction)
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
