Media-blasting... #639398
03/14/10 01:09 AM
03/14/10 01:09 AM
ID/MT
Cheeto Offline OP
Cheeto  Offline OP
ID/MT
Do it myself or farm it out?
I plan to completely dis-assemble the two trucks I'm working on to get all the rusty spots cleaned up. Should I buy a Harbor Freight blaster and do this one panel at a time over a large tarp or would it be cheaper in the long run to let the pros handle it? What media should I use?
Anybody have home-made blasting booth (not cabinets) pics/tips?
Cheeto
It's not perfect.
It's not correct.
It's not yours!
Re: Media-blasting... [Re: Cheeto] #639399
03/14/10 08:20 AM
03/14/10 08:20 AM
Detroit, MI
DetMatt Offline
DetMatt  Offline
Detroit, MI
If you do plan on doing this yourself, DO NOT go to H.F. to purchase a blaster!. One from there might be fine for very intermitent use but certainly not if you plan on doing as much as it sounds like you need to do. Hire it done, it will be much cheaper and less agravating in the long run. The only way I would take on doing a whole car myself is with good equipment, no neighbors that lived close and... NO, FORGET IT!, JUST HIRE IT DONE!!!.
`68 Road Runner "JUNKYARD DOG" `70 A66 FK5 Challenger, Rough project. `68 Coronet R/T Black & white 4 speed. `97 Dodge 1500 4X4, 228,000 miles and going strong!
Re: Media-blasting... [Re: DetMatt] #639400
03/14/10 11:25 AM
03/14/10 11:25 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
doing media blasting myself i would say to farm it out. those small blasters are ok for small jobs, big jobs arent as much fun. you will there days and use a ton of media.
so in the long run it wont be cheaper doing it yourself.
Re: Media-blasting... [Re: chrisf] #639401
03/15/10 11:22 AM
03/15/10 11:22 AM
Minnesota
72blubird Offline
72blubird  Offline
Minnesota
I agree with the others have it done.
What was I thinking....
Re: Media-blasting... [Re: 72blubird] #639402
03/16/10 09:51 PM
03/16/10 09:51 PM
Iowa,US
4bbl Offline
4bbl  Offline
Iowa,US
ditto,, farm it out
4bbl If you can't hear it coming what's the point.......
Re: Media-blasting... [Re: 4bbl] #639403
03/16/10 11:27 PM
03/16/10 11:27 PM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
never used media,,,but helped a friend sand blast a 55 truck frame,in a drive way in a neighborhood full of houses,,,small comperssor,,5 horse single stange pump,,canister type sand tank,,,
made a booth out of the blue tarps you buy at the home stores,,,when the tank was empty,we swept up the sane,,sifted it thru a fine screen in to a bucket,,,then re-used it,, was a little messy,,but not bad,,,but that was a frame not sheet metal,,,if you dont know what your doing,,and your body is sorta straight,,you can really mess things up,,,,but to say you done it your self,says a lot also,,,
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: Media-blasting... [Re: fstfish66] #639404
03/16/10 11:30 PM
03/16/10 11:30 PM
Iowa,US
4bbl Offline
4bbl  Offline
Iowa,US
"done it myself" is good brag!
Re: Media-blasting... [Re: 4bbl] #639405
03/17/10 08:47 AM
03/17/10 08:47 AM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
I too was wanting to blast my 57 project. I think i will blast the frame first and see how that go's.Since i am doing this at the farm, nieghbors are not an issue. (1/8 mile in either direction)
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: Media-blasting... [Re: rattler] #639406
03/18/10 12:12 AM
03/18/10 12:12 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
If your going to use sand, be sure to wear a good resperator, that sand dust will tear up your lungs, really.
Gene
Re: Media-blasting... [Re: poorboy] #639407
03/22/10 09:31 PM
03/22/10 09:31 PM
Upstate, NY
sixpack4spd Offline
sixpack4spd  Offline
Upstate, NY
Nothing wrong with a Harbor Freight blaster. You'll wear out a couple of hoses and valves in the process. Use Black Beauty (coal slag - look it up) instead of sand. Don't reuse whatever blasting media you use. It cuts better when fresh. Old dull media will heat and warp the metal panels.
If you don't have a professional grade compressor that will put out lots of air, DON'T BOTHER. You'll spend most of your time waiting for the compressor to pump back up.
Re: Media-blasting... [Re: sixpack4spd] #639408
03/23/10 12:03 AM
03/23/10 12:03 AM
Austin, TX
lunacy Offline
lunacy  Offline
Austin, TX
I can agree on the compressor. I have a 30 gallon and it barely hangs in there for my blasting cabinet. I'm using aluminum oxide, works great for cutting rust off the thick metal brackets and the intake I've blasted, although very dusty, I am working on a venting system using an old computer power supply and a couple of fans.
