Re: How can I check to see IF my rear axle housing is bent?
[Re: topside]
#639222
03/14/10 09:26 AM
03/14/10 09:26 AM
Posts: 10,750 North Dakota
6PakBee
North Dakota
I just jack the vehicle up and mount two bare wheels (no tires). Then I measure from the outside of one rim to outside of the other rim in roughly four places, front, back, top, bottom. Then I rotate the wheels about 1/4 turn and repeat. Do this four times. Take all four readings at each spot and average. The difference between averages is the amount of bend in both planes. Works better with a helper.
[Re: convx4]
#639223
03/15/10 11:04 PM
03/15/10 11:04 PM
Posts: 587 minot north dakota
ledft79
minot north dakota
The Rear axle in question is in a 1989 2wd dakota. My aliment guy said there was some thing wrong(bent)with it. If you use your hand to measure between the front of the tire and the wheel well lip their looks to be a 1/2" difference side to side. I bought this truck used and I know the guy replaced the rear end. Is there some way I can check to see if the housing is bent?
I'll bet the rear end is not in the truck strait, rather than being bent. 1 way to know for sure, takes a little wrenching. Pull the cover and remove the axles, look at the oil in the tubes with a light at the other end. if the axle is bent, there will be a curve in the oil left in the tubes, you cant miss it. If it is not bent, the oil stream will be strait as an arrow. Also the alignment readings will tell you if it is bent, toe and or camber will be off on one end while the other end will be near normal. If toe is positive on one end and negative nearly the same amount on the other end, then it is not installed strait. There could be things bent, causing it to be installed crooked.
DRIVE EM, DONT HIDE EM.
