Re: head porters a little help please
[Re: sshemi]
#638616
03/13/10 07:56 AM
03/13/10 07:56 AM
Posts: 15,487 Florida
scratchnfotraction
if you have to use the 273 heads, then yes it would be good to bump the ex to a 1.60 valve and pocket port the bowl I better head would be a closed chamber #302 318 head cant hurt go with the 1.88 valve,but the shrouding is the hold up in flow..even with bore notches I have just went 1.60 ex and hoged out the ex bowl/port on some back yard engines,that gave a good bit of pop to it for the effort you gonna flow bench them?
[Re: scratchnfotraction]
#638619
03/14/10 01:25 PM
03/14/10 01:25 PM
Posts: 2,128 sweden
sshemi
sweden
well then,cant go wrong with a vac in the canary islands
enjoy the break and get some R&R,drink a mi-ti for me
-mike
Already done, and for another couple onother of hundreds members too.
The weather is nice and the beers tastes so good.
[Re: sshemi]
#638621
03/15/10 11:37 AM
03/15/10 11:37 AM
Posts: 1,019 Finland
mafo
Finland
I would go with 318 heads...save the 273 ones for the matching numbers crowd I could flowtest them for free if it helps but you have to come here and set them up on the bench yourself...
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: sshemi]
#638623
03/17/10 07:16 AM
03/17/10 07:16 AM
Posts: 2,128 sweden
sshemi
sweden
