Re: Muffler suggestion
[Re: Belvedere2]
#638389
03/12/10 08:18 PM
03/12/10 08:18 PM
Posts: 1,562 Clinton Twp, Michigan
DerickS
Sounds just like mine except I have 2.5in and a full exhaust. I'd bet if you ran a full exhaust and not turndowns you like it. Mine is not loud at all.
You know i've thought about that but I have a BGHR220 fuel pump, it is so loud i'd be afraid it would drive me nuts!
[Re: Belvedere2]
#638391
03/12/10 08:40 PM
03/12/10 08:40 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
We run the Ultraflows and love them, less drone than a flowmaster and does not sound like a tin can.
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
[Re: Belvedere2]
#638392
03/12/10 08:41 PM
03/12/10 08:41 PM
DerickS
What is it? The empty trunk type drone? Try some dynomat. Sounds like alot of vibration going on.
Yeah I screwed up and welded the mounting bracket to the rear frame rail! ugh....Where do I get dynomat from?
[Re: DerickS]
#638393
03/12/10 08:42 PM
03/12/10 08:42 PM
Posts: 5,080 organ
maximum entropy
organ
if all you're worried about is noise inside the car, try tailpipes.
[Re: 65signet]
#638394
03/12/10 08:42 PM
03/12/10 08:42 PM
DerickS
Did u run tailpipes??
[Re: 727builder]
#638396
03/12/10 09:22 PM
03/12/10 09:22 PM
Posts: 1,880 USA
Ron Silva
USA
Tail Pipes will help a BUNCH!
I like these Walker Dynomax Super Turbos. They are 3" in and out and the biggest case they make. Tried these on the Demon and took off the 3-1/2" Flowmaster Delta Flow mufflers and the car was just as fast or faster.
These are on the Valiant. Why screw with a good thing?
SRT DEMON ONE SEAT
[Re: Bob's71R/T]
#638398
03/12/10 09:25 PM
03/12/10 09:25 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
Tailpipes,,,,, ( i have the 3" ultra flows,,with TTI tail pipes,,,and the car is not that loud )
[Re: 69CHARGERMD]
#638400
03/12/10 11:55 PM
03/12/10 11:55 PM
DerickS
Do you have any sound bytes of it?
[Re: DerickS]
#638402
03/13/10 05:52 AM
03/13/10 05:52 AM
69CHARGERMD
KENTUCKY
Derrick Sorry, no sound bites. I did have 3" 2 chamber flowmasters,,with turndowns under the car and it was LOUD.. The Ultraflows with the tailpipes are MUCH less,,,sound wise...almost too quiet for me,,, I think the tailpipes will help alot..puts all the noise out the BACK of the car,,instead of reverberating off the bottom of the car,,, I did find a few links on youtube that might help... DOUG http://www.youtube.com/watch?v=ym0blQqjCEEhttp://www.youtube.com/watch?v=j4iyWDFlsM0http://www.youtube.com/watch?v=AxN23wfw-Zs
[Re: 69CHARGERMD]
#638403
03/13/10 05:54 AM
03/13/10 05:54 AM
69CHARGERMD
KENTUCKY
Derrick, the last link i posted ( a purple charger ),,,, sounds identical to mine now,,,fyi. Doug
[Re: 69CHARGERMD]
#638404
03/13/10 09:32 AM
03/13/10 09:32 AM
DerickS
Thanks Doug, the camaro sounded great. I have an H pipe in mine and I know the X's make them quieter but i cant afford it.
