Master cylinder rebuild? #638122
03/12/10 04:40 PM
03/12/10 04:40 PM
Smyrna,TN.
cudagregs Offline OP
Smyrna,TN.
Who rebuilds master cylinders and how much does it usually cost? Thanks....Greg
Re: Master cylinder rebuild? [Re: cudagregs] #638123
03/12/10 04:48 PM
03/12/10 04:48 PM
scratchnfotraction Offline
get a rebuild kit and do it yourself
just buy a reman MC is fastest and safest,IMHO
it sorta like a clutch slave cyl to rebuild
2 bolt or 4 bolt ?
you can hone the bore with a wheel cyl tool if you get the over size kit and mic it
not much need for that kinda stuff any more with all the reman stuff around
if its a 4 bolt MC I allways adapt it to a alum 2 bolt MC myself..
Re: Master cylinder rebuild? [Re: scratchnfotraction] #638124
03/12/10 04:57 PM
03/12/10 04:57 PM
Smyrna,TN.
Smyrna,TN.
I want to keep the original stock look. I have the original one off my car and the rebuilt mc look nothing like the origianl. I spent 2 hours today at my local part stores trying to find a 1' bore mc like mine and they are different. I have a 70 barracuda and considered an A-body mc but they are very different too.
Re: Master cylinder rebuild? [Re: cudagregs] #638125
03/12/10 05:01 PM
03/12/10 05:01 PM
I get the last rebuild kit from napa for an a-body one
simple to do yourself
we just have an alt/start shop around my area
have you looked local in your area for a rebuilder?
guess thats what your asking...Duh
aleast see if the have the correct kit for yours
Re: Master cylinder rebuild? [Re: scratchnfotraction] #638126
03/12/10 05:07 PM
03/12/10 05:07 PM
Smyrna,TN.
Smyrna,TN.
Thanks,I'll check with Napa on the rebuid kit. They may have a correct looking mc.
Re: Master cylinder rebuild? [Re: cudagregs] #638127
03/12/10 05:17 PM
03/12/10 05:17 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
If its a disk brake car the dart kit is not the same and NOS kits are few and far and really expensive.
NS1AAR
Re: Master cylinder rebuild? [Re: scratchnfotraction] #638128
03/12/10 05:33 PM
03/12/10 05:33 PM
What Scratch said, I'd score a kit & hone it LIGHTLY w a wheel cyl hone or a dingleberry hone of the proper dia/grit & some solvent then check it for pits and possibly for over the limit oversize & clean it w solvent & put it together w brake fluid.
Re: Master cylinder rebuild? [Re: RapidRobert] #638129
03/12/10 07:35 PM
03/12/10 07:35 PM
Smyrna,TN.
Smyrna,TN.
Thanks guys for all the info...
