moog offset bushing install?? #637829
03/12/10 01:28 PM
03/12/10 01:28 PM
Madison, Wisconsin
chrisnben Offline OP
Madison, Wisconsin
Has anyone used the K7103 offset UCA bushings? Which direction is the correct installation? There is an arrow on the bushing. Any help would be great! Didn't want to install them and be wrong- once they're in that's it! thanks!!!!
'70 Cuda "Badfish 2"- in the works
Home of MoPar University- We school 'em one at a time!!
Re: moog offset bushing install?? [Re: chrisnben] #637830
03/12/10 01:42 PM
03/12/10 01:42 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Do not install per the instructions in the kit.
Then adjust for most caster and caster to match side to side.
Re: moog offset bushing install?? [Re: chrisnben] #637831
03/12/10 05:25 PM
03/12/10 05:25 PM
just visualize that the UCA and bushings are all soft putty and you are pulling the upper ball joint rearward by hand to increase positive caster. This would pull the cam bolt hole closer to the inside edge on the front bushing and the cam bolt hole closer to the outside edge on the rear bushing
Re: moog offset bushing install?? [Re: RapidRobert] #637832
03/12/10 07:21 PM
03/12/10 07:21 PM
Madison, Wisconsin
Madison, Wisconsin
Thanks guys, wonder why the damn instructions say to put each bushing in tha same way- both arrows outward?? Makes sense to put them opposite.
Re: moog offset bushing install?? [Re: chrisnben] #637833
03/12/10 08:04 PM
03/12/10 08:04 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Both arrows outward would give the most negative camber. Both inward would give you the most possible positive camber.
Installing the front bushing with the hole farthest from the ball joint and the rear bushing closest to it it will shift the ball joint aft giving the most caster which is what these cars are lacking in the alignment arena.
Re: moog offset bushing install?? [Re: chrisnben] #637834
03/12/10 10:02 PM
03/12/10 10:02 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
We are altering the originally intended use of these offset bushings.
They were made for rust buckets and past collision damaged cars that have the shock towers bent in.
So ignore the instructions in the box if you are looking for increased caster.
Re: moog offset bushing install?? [Re: autoxcuda] #637835
03/12/10 10:20 PM
03/12/10 10:20 PM
We are altering the originally intended use of these offset bushing.
So ignore the instructions in the box is you are looking for increased caster.
That's what we have been missing on this deal.
Re: moog offset bushing install?? [Re: RapidRobert] #637836
08/04/10 04:00 PM
08/04/10 04:00 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
So... how much camber can you gain back with these?
Having issues on my 72 RR. Alignment tech doesn't think the bushings will get the job done. Suggests a frame pull.
I'm more inclined to spend $300 on adjustable A-arms.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: moog offset bushing install?? [Re: 471Magnum] #637837
08/04/10 04:52 PM
08/04/10 04:52 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Don't let him pull the frame until you have SAI numbers and an understanding of them!
http://www.anewtoronto.com/wheel%20alignment.html
Re: moog offset bushing install?? [Re: 471Magnum] #637838
08/05/10 02:15 AM
08/05/10 02:15 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
What alignment numbers is he getting now? What alignment feature is he having problems with (caster, camber, toe)? How much experiance does the alignment technician have?
If it is so messed up that offset bushing can not help, maybe it should have a frame pull. Is there indication of a past hit?
Are you running poly strut bushings. They are thicker than stock and you can remove about 3/16" from the sleeve and rear bushing to get the stock thickness and will aid in getting caster.
Re: moog offset bushing install?? [Re: autoxcuda] #637839
08/05/10 08:16 AM
08/05/10 08:16 AM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
LF
Camber -0.6
Caster -0.9
Toe -0.18
RF
Camber -1.2
Caster -0.6
Toe -0.10
First thing I asked was whether or not he checked the ride height. He hadn't, which led me to believe he hadn't aligned many Mopars. I later checked it myself at home and it was pretty low, so I set it to spec. Before and after I spot checked the camber with a carpenters level. There is about 1/4"-1/2" of negative camber on each side.
Car was pulled from the scrap heap and completely restored. No sign of collision damage, but there no history on the car either.
I think all the bushings are stock.
-Jim
Re: moog offset bushing install?? [Re: 471Magnum] #637840
08/05/10 08:51 AM
08/05/10 08:51 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
With those numbers if he cant get caster and camber to at least positive 2 degrees caster and about .5 camber run dont walk.I had like neg 5 degrees on my 65.Installed the offsets and Im about at 0 on caster.I do my own alingments so I know where its right.Id like a bit more caster but my cars a rust bucket and Im not spending 300 bucks on tube A arms.Rocky
Chrysler Firepower
Re: moog offset bushing install?? [Re: 471Magnum] #637841
08/05/10 12:48 PM
08/05/10 12:48 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Moog offset should be able to get that to stock specs.
The question now is the effort and talent of the alignment guy.
What are the positions of the front and rear UCA cam adjusters on both sides? Pictures of the cams like I took above?
LF
Camber -0.6
Caster -0.9
Toe -0.18
RF
Camber -1.2
Caster -0.6
Toe -0.10
Re: moog offset bushing install?? [Re: autoxcuda] #637842
08/05/10 01:47 PM
08/05/10 01:47 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
I know the rear bolts are pretty much at the end of their travel to the outboard. The front ones have some room to work.
As far as the talent of the alignment guy, I really can’t say. The shop I took it to does a lot of specialty work though which is the only reason I considered bring it there in the first place. In the past, I’ve used another shop across town and had pretty good luck with my Mopars.
Just to be clear, he only checked the alignment. He did not attempt to correct it because he did not think there was range left in the cam bolts to get it were it needs to be.
-Jim
Re: moog offset bushing install?? [Re: 471Magnum] #637843
08/05/10 02:45 PM
08/05/10 02:45 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
You're not way way off. You need more postive camber. If you install the 7103 offset like the instructions in the box where both front AND rear bushings move BOTH a-arm legs OUT you will be fine. Like WildBill posted, "Both inward would give you the most possible positive camber."
Offsets even installed to gain caster like the diagram above might work.
That or try and see how much you can move the front adjuster outward. Is the front cam adjusted inward, outward, or middle now?
Re: moog offset bushing install?? [Re: chrisnben] #637844
08/05/10 06:15 PM
08/05/10 06:15 PM
None
71rm23 Offline
71rm23  Offline
None
I'm interesting in this subject as well. Thanks to the OP for bringing it up. This is very informative. I'll be working on mine as well in the future. My question is this: Who do you guys take your car to to get it aligned? Word of mouth, friend, do it yourself? I just dont want some kid telling me that my car needs this and that when it doesnt. Don't want someone who doesnt appreciate or know what a true Mopar is.
Re: moog offset bushing install?? [Re: 71rm23] #637845
09/03/10 04:08 AM
09/03/10 04:08 AM
Bern, Switzerland
6o4o Offline
6o4o  Offline
Bern, Switzerland
autoxcuda - wouldn't you want the max. negative camber or why do you propose to get max. positive camber? I thought that's not good for turns and you want max. neg. camber?
Re: moog offset bushing install?? [Re: 6o4o] #637846
09/03/10 04:36 AM
09/03/10 04:36 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
In general, yes you would.
But in 471Magnum's case he has to much negative camber and the UCA's adjusted all the way outward (toward positve camber) and he is still too much in the negative range. It appears he is out of adjustment range. It's like the shock towers are both bent inwards.
So if he installs the offsets to push the UCA's out, he gets in the -0.25 to +0.25 range or more and still have adjustment left to get some positve caster out of it.
In 471Magnum's case, you use the offsets as a repair type deal to make up for something bent/wrong. You install the offset depending which way things are bent.
Re: moog offset bushing install?? [Re: autoxcuda] #637847
09/16/10 07:50 PM
09/16/10 07:50 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
So... what's the maximum additional camber that you can achieve with the offsets?
Just guesstimating some dimensions and doing a little trigonometry, I'm thinking about 1 degree max.
-Jim
Re: moog offset bushing install?? [Re: 471Magnum] #637848
09/16/10 11:57 PM
09/16/10 11:57 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
turning the front cam bolts out will raise the camber and caster.the rear bolt out will raise camber but lower caster.I always shoot for about 0 deg camber and about 3.0 deg positive caster.important to have equal readings side to side.camber is a tire wearing angle ,so that one is more important than caster.Positive Caster helps take the wander out.the more caster the more stable the car drives.I like about 1/8 inch toe in.Common caster spec for bmw's mercedes,other sport cars is in the neigborhood of 9-10 deg. positive caster.The only downfall with positive caster.Is with manual steering.makes slow speed turning alittle tougher.
Do alignments in this order.Tire psi,ride height,camber.caster and then toe.make sure the lower control arm bushing are good.Most common reason for too much neg camber.Yes the offset bushing will give you the adjustment you need.
