Eddy 1406 carb ? #637693
03/12/10 12:11 PM
03/12/10 12:11 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
got a line on a Eddy 1406 carb whats the specs on it, is it a good carb? i hear complaints about eddy carbs, other #'s on it are 2169 & 8867 what's a fair $$ for it used
Re: Eddy 1406 carb ? [Re: ademon] #637694
03/12/10 12:59 PM
03/12/10 12:59 PM
NY usa
540challenger Offline
NY usa
The eddy 1406 if i remember right should be a 600CFm electric shoke. It is a great all around carb imo and i used them thigns from my 273 to my 408 "i did upgrade too a bigger carb later"
Re: Eddy 1406 carb ? [Re: ademon] #637695
03/12/10 01:01 PM
03/12/10 01:01 PM
Melbourne, FL
dwbiggs Offline
super gas
dwbiggs  Offline
super gas
Melbourne, FL
Had one...didn't like it...switched to Holley and never looked back. I suppose for a stock or near stock build low CU IN motor it would work OK. Probably wouldn't use it on anything bigger than a 318.
Re: Eddy 1406 carb ? [Re: dwbiggs] #637696
03/12/10 01:16 PM
03/12/10 01:16 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
have one, has been on a 360 and 318, great carb, $100 used is what I usually see them go for....
2017 Grand Cherokee Overland
Re: Eddy 1406 carb ? [Re: dwbiggs] #637697
03/12/10 01:17 PM
03/12/10 01:17 PM
NY usa
NY usa
My ran fine on my 408 crisp thorrtle respondance no off idle stumple. Plenty of Vac 18" and crisp idle. It did run out of steam up stairs but thats was only b/c on the lack of CFM. What issues did you have???
Re: Eddy 1406 carb ? [Re: 540challenger] #637698
03/12/10 01:25 PM
03/12/10 01:25 PM
Melbourne, FL
dwbiggs Offline
super gas
dwbiggs  Offline
super gas
Melbourne, FL
Had a 1406 on a Buick 350 and a 1407 on a 440, both had hot start problems and flat spots...put Holley 750 on the 440 and it was like night and day. Went back to the stock QJet on the Buick.
Re: Eddy 1406 carb ? [Re: dwbiggs] #637699
03/12/10 01:36 PM
03/12/10 01:36 PM
NY usa
NY usa
Hmmm i never had any of those problems. Did yout open up the carbs or just run them out of the box. Either i will say that i notice that my demon doesn't empty out the bowls as fast as the eddy i had after sitting for a few days in the warmer summer weather.
I am guess the location of the bowl areas has to do with it
Re: Eddy 1406 carb ? [Re: ademon] #637700
03/12/10 01:37 PM
03/12/10 01:37 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
They are generally good carbs, just not race carbs, pretty similar performance to the stock AVS you'd find on a 68-70
340. I find cores vary allot in price, anywhere between $25.00-$100.00 depending on condition. If you want more performance with good all around economy a thermoquad would be my next step up choice.
Re: Eddy 1406 carb ? [Re: ScottSmith_Harms] #637701
03/12/10 01:58 PM
03/12/10 01:58 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Been using the same one for several years ..1st on 318 dart and now on 73 duster.
for a everyday driver they are good carbs..
Tony
70 AARCuda Vitamin C
Re: Eddy 1406 carb ? [Re: 70AARcuda] #637702
03/12/10 04:33 PM
03/12/10 04:33 PM
I have one on a stock 318. stumbles, runs lean, (electric) choke comes off way too fast but in fairness I need to work on it, a guy here said to start it/fill the bowls then see if the fuel level is up to the slot in the float baffle for starters. I really need a LM-1, I'm tired of guessing all the time and people have them run flawless.
Re: Eddy 1406 carb ? [Re: RapidRobert] #637703
03/12/10 05:13 PM
03/12/10 05:13 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Several years ago I ran that carb on my basically stock 383. Great little carburetor for the street. Engine ran great.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Eddy 1406 carb ? [Re: Junky] #637704
03/12/10 06:21 PM
03/12/10 06:21 PM
scratchnfotraction Offline
got mine tuned the way i likes it on the 318
idles at 800-850 rpms,stomp it and it wont miss abeat all the way to 5000rpms
a stacked alum plate/gaskets and blocking the heat cross over took care of the perking bowls and hot starts
mines a manual choke and runs a little fat at idle,and will run out of cfms on a long hard blast
the eddie 750 was fat all over the place,could not find a sweet spot with it,but could tell it had more cfms on the top end a good bit over the 600 though..
but the 600 is so much more street friendly and has more throttle responce with it which make driving a little more plesurable for daily duty,IMHO
I want to see how the holley 650,manual 2ndary,spredbore,double pumper,works on the stock 440
never had one of these to play with before,so I will see if its just another holley gas hole
Re: Eddy 1406 carb ? [Re: scratchnfotraction] #637705
03/12/10 06:26 PM
03/12/10 06:26 PM
Go easy Scratch, you know how owly people get here on Fri and Sat nights
Re: Eddy 1406 carb ? [Re: RapidRobert] #637706
03/12/10 06:34 PM
03/12/10 06:34 PM
oh I am not knocking any of the carbs..well other than a bbd 2-v
if you want to go fast and race cant beat holley gas holes,IMO
I am not on the level to fool with a thermobog,so it wont take much for me to ditch one
but I like simple and trouble free which my 600 eddie gave almost 8 yrs out the box till a few summer ago when the crap was in all the gas and clogged it up
blew it out and reset it,been trouble free since then
yea,I am used to the bashing here
Re: Eddy 1406 carb ? [Re: scratchnfotraction] #637707
03/12/10 06:52 PM
03/12/10 06:52 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
in my experience, the Eddy carbs are better cruiser/econo carbs, not tuned real well for performance out of the box. instead they focus on mileage.
whereas holley is typically a performance tune OOTB, and economy isn't even a thought.
an Eddy 800CFM w/ electric choke, OOTB gave me about 14MPG overall on the big block I put in my Dakota.
the Holley is OOTB with the exception of just 1 jet size larger on the secondaries, and it's only getting me 10MPG overall.
on the engine dyno, the Holley made about 75hp more than the eddy, OOTB. I didnt' even bother messing with the eddy trying to tune it and just went with the holley.
**Photobucket sucks**
Re: Eddy 1406 carb ? [Re: 70Cuda383] #637708
03/13/10 01:40 AM
03/13/10 01:40 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
1406
1407
