Re: 440 Rebuild
[Re: RemCharger]
#636934
03/11/10 08:49 PM
03/11/10 08:49 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
I say it will work out cheaper and less agravating in the long run if he does a rebuild now before dropping it in.
Still, defining "budget" like you say is the key word here.
So,,,,, what's the budget?
Re: 440 Rebuild
[Re: Abitrusty]
#636935
03/11/10 09:17 PM
03/11/10 09:17 PM
RapidRobert
I'd drop the eng/trans in & run it & see what you got, one step up would be to replace the fuel/water/oil pumps. Next step would be to R&R the cam/lifters/timing chain. Next step would be to R&R the rings/rod/main bearings which is called an "over the fender overhaul" which is done w the eng/trans still in place which keeps you from spending on extras such as cam bearings/turning the crank/boring/honing the eng as these charges mount up fast and if an over the fender overhaul is a good plan is dependent on the piston/bore clearance and bore out of round/taper/journal surfaces but an O.F. overhaul can last 100K miles. But if your are going to OH the 727 (get Munroes tranny book) your in a better position to tear down the eng at the same time. Projects take alot of down time, I'd get it up & running and let him burn some rubber and then he could easily do a compression test/check oil consumption without having to wait for months
Re: 440 Rebuild
[Re: Commando1]
#636938
03/12/10 03:45 AM
03/12/10 03:45 AM
DaytonaTurbo
Manitoba, Canada
Do the full rebuild now, you will regret not doing it if you skip it. I did a hone'n're-ring to my 440 and it was okay, but it's a low-comp mid 70's 440 like yours and it's just not the same as doing it proper.
I would first take the motor apart and have it checked. I'd take the crank and block over to your machine shop so they can tell you how much overbore and if the crank needs to be ground. Then buy your parts. Get a set of KB237 pistons, reuse your stock rods, new bearings, gaskets, etc. Build a good bottom end. You can cleanup and reuse the stock heads so later on he can replace then with a set of 440source or edelbrock rpm heads if the budget does not allow that now. You will be much happier with a solid bottom end that will allow you to build a decent compression ratio. Spend more, yes, but WAY worth it having a solid, well built bottom end rather than a tired low-comp smogger with a new set of rings. Trust me I've been there.
