Re: Headlight re-finishing, kits do they work?
[Re: CrazyD]
#636833
03/11/10 06:31 PM
03/11/10 06:31 PM
The 3M kit worked for me--do each step a little longer than you think it needs it--will turn out great--that little tip about a dime size squirt of the final polish is a good tip --more and it will fly all over everything!
[Re: ]
#636834
03/11/10 07:50 PM
03/11/10 07:50 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Just checked and that is what he was using too.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: MoparforLife]
#636835
03/11/10 08:36 PM
03/11/10 08:36 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
Just remember, you are sanding away the (defective) protective finish, exposing bare plastic. You'll need to keep the surface waxed or it will begin to deteriorate again before too long.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: GTXX]
#636838
03/11/10 11:40 PM
03/11/10 11:40 PM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
why spend money on a kit? a worn out piece of 800-1000 grit paper and some polish with the buffer on low speed will do the same thing, cost about a quarter.
I think the kits are so that the average person won't have to remove the lens from the vehicle. I have used the 3M kit and my method works much better,but I have to remove the lens.
[Re: GTXX]
#636839
03/12/10 01:11 AM
03/12/10 01:11 AM
That's what I did last week.
Wet sanded the headlights and then polished with a powerball/mothers polish.
#636840
03/12/10 01:19 AM
03/12/10 01:19 AM
goldmember
Gainesville,FL
Skip the Mothers polish and powerball,use a quality plastic polish on a flannel 6" buff @3450rpm.
[Re: goldmember]
#636841
03/12/10 01:22 AM
03/12/10 01:22 AM
It was fast, easy, cheap and best of all sitting on the shelf about 3' from me...
