Headlight re-finishing, kits do they work? #636830
03/11/10 04:52 PM
03/11/10 04:52 PM
North Pole,New York
formula_s Offline OP
North Pole,New York
3M has one at Advance. Do these or any others get rid of that frosted appearance from the plastic?
Re: Headlight re-finishing, kits do they work? [Re: formula_s] #636831
03/11/10 05:01 PM
03/11/10 05:01 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Yes - take your time and they come out clearer than knew. Don't know if they are all teh same though and I don't remember the ones that he was using the day I was out there.
Re: Headlight re-finishing, kits do they work? [Re: formula_s] #636832
03/11/10 05:06 PM
03/11/10 05:06 PM
CrazyD Offline
CrazyD  Offline
3M kit worked great - I had low expectations, was pleasantly surprised at results - nice and clear.
Re: Headlight re-finishing, kits do they work? [Re: CrazyD] #636833
03/11/10 06:31 PM
03/11/10 06:31 PM
The 3M kit worked for me--do each step a little longer than you think it needs it--will turn out great--that little tip about a dime size squirt of the final polish is a good tip --more and it will fly all over everything!
Re: Headlight re-finishing, kits do they work? [Re: ] #636834
03/11/10 07:50 PM
03/11/10 07:50 PM
Upper Midwest
Upper Midwest
Just checked and that is what he was using too.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Headlight re-finishing, kits do they work? [Re: MoparforLife] #636835
03/11/10 08:36 PM
03/11/10 08:36 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Just remember, you are sanding away the (defective) protective finish, exposing bare plastic. You'll need to keep the surface waxed or it will begin to deteriorate again before too long.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Headlight re-finishing, kits do they work? [Re: formula_s] #636836
03/11/10 09:40 PM
03/11/10 09:40 PM
St Louis, Missouri
Runnin74 Offline
Runnin74  Offline
St Louis, Missouri
I just sanded and polished the ones on my van then clear coated them with a UV resistant clear from U-POL.
CLEAR#1™: High Gloss Clear Coat - the one in the copper colored spray can. It can fog if you apply it in high humidity -don't ask me how I know.
Re: Headlight re-finishing, kits do they work? [Re: formula_s] #636837
03/11/10 11:37 PM
03/11/10 11:37 PM
Rome, GA
GTXX Offline
GTXX  Offline
Rome, GA
why spend money on a kit? a worn out piece of 800-1000 grit paper and some polish with the buffer on low speed will do the same thing, cost about a quarter.
Re: Headlight re-finishing, kits do they work? [Re: GTXX] #636838
03/11/10 11:40 PM
03/11/10 11:40 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I think the kits are so that the average person won't have to remove the lens from the vehicle. I have used the 3M kit and my method works much better,but I have to remove the lens.
Re: Headlight re-finishing, kits do they work? [Re: GTXX] #636839
03/12/10 01:11 AM
03/12/10 01:11 AM
That's what I did last week.
Wet sanded the headlights and then polished with a powerball/mothers polish.
Re: Headlight re-finishing, kits do they work? #636840
03/12/10 01:19 AM
03/12/10 01:19 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Skip the Mothers polish and powerball,use a quality plastic polish on a flannel 6" buff @3450rpm.
Re: Headlight re-finishing, kits do they work? [Re: goldmember] #636841
03/12/10 01:22 AM
03/12/10 01:22 AM
It was fast, easy, cheap and best of all sitting on the shelf about 3' from me...
Re: Headlight re-finishing, kits do they work? #636842
03/12/10 01:24 AM
03/12/10 01:24 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Right and like most folks you can't see what your missing unless you did it the right way and compared it to the shortcut method. In my line of work I won't cut a corner and compromise the finished product,many of my competitors do and it shows.
Re: Headlight re-finishing, kits do they work? [Re: goldmember] #636843
03/12/10 03:52 AM
03/12/10 03:52 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
My brother used it on his 92 daytona. His headlights and fog lights were awful and yellow looking. Took them off did the sanding/polishing with the kit and they look great. Not brand new looking but pretty close. I think a plastic non-replacable lens is the stupidest idea ever. You get an older car like his where a repro lens is not available so you're stuck with old junk.
