Who sells crank trigger distributor #636815
03/11/10 03:46 PM
03/11/10 03:46 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
I hate to buy a tall msd distributor just to gut it and weld the shaft. Crank trigger with dist in stock location for use with indy heads and fab valve covers. Does anyone sell a distributor for distribution only?
Re: Who sells crank trigger distributor [Re: galen] #636816
03/11/10 04:20 PM
03/11/10 04:20 PM
AndyF Offline
AndyF  Offline
Nobody sells a Mopar big block crank trigger distributor. You can buy the MSD and run it solid (no welding required) or you can find an old lean burn distributor in a wrecking yard and run it. If you have a Jesel belt drive on the motor you can also run a Jesel belt drive distributor. That is what I finally did and it really helped clean up the ignition.
Re: Who sells crank trigger distributor [Re: AndyF] #636817
03/11/10 04:22 PM
03/11/10 04:22 PM
AndyF Offline
AndyF  Offline
Another look
Re: Who sells crank trigger distributor [Re: galen] #636818
03/11/10 04:24 PM
03/11/10 04:24 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
I use a stock lean burn dist. they have a solid shaft. All you have to do is remove the magnetic pickups. Been using one on a S/G roadster for 9 years and it's still rock steady. You can buy one rebuilt from a autoparts store.
Re: Who sells crank trigger distributor [Re: galen] #636819
03/11/10 04:28 PM
03/11/10 04:28 PM
AndyF Offline
AndyF  Offline
Another option is to lobby for someone to build an inexpensive distributor with no advance curve and no electronics. Talk to Todd Ryden at MSD or call the guys at Custom Wire Sets or Brandon at 440Source. ProComp makes a distributor so that would be another place to call or Crane or Mallory. Someone out there should be interested in building a dead simple distributor with just a shaft, rotor, housing and cap.
Re: Who sells crank trigger distributor [Re: supercomp] #636820
03/11/10 08:33 PM
03/11/10 08:33 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Yep,
Same story, simple, effective, and cheap.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Who sells crank trigger distributor [Re: MoparBilly] #636821
03/11/10 09:23 PM
03/11/10 09:23 PM
New Brunswick, Canada
TrxR Offline
TrxR  Offline
FAST makes a dual synch distributor I believe for crank trigger and cam trigger.
Re: Who sells crank trigger distributor [Re: AndyF] #636822
03/11/10 11:11 PM
03/11/10 11:11 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
Andy I am running a Jesel belt drive, I did not think you could run a front mount water pump with the front mount distributor. I see you have one in the picture. Who makes that pump? Thanks guys for the replies, I appreciate it. Galen
Re: Who sells crank trigger distributor [Re: galen] #636823
03/12/10 12:08 AM
03/12/10 12:08 AM
AndyF Offline
AndyF  Offline
That is a reverse flow water pump. It will fit under the Jesel belt drive distributor with a little work. I made my own bracket and used a longer belt to make it fit. The motor plates that I make are designed to work with the special distributor bracket. (I have some of these parts for sale if you're interested as I've moved on to some different projects)
Re: Who sells crank trigger distributor [Re: AndyF] #636824
03/12/10 12:09 AM
03/12/10 12:09 AM
AndyF Offline
AndyF  Offline
Here is another picture that shows some other parts.
Re: Who sells crank trigger distributor [Re: galen] #636825
03/12/10 12:15 AM
03/12/10 12:15 AM
AndyF Offline
AndyF  Offline
Here is another way to run a standard water pump with the Jesel belt drive distributor. Some guys don't want to run a reverse flow water pump so this is the setup for them. Others want a reverse flow water pump. I make kits for both applications.
