Wire Terminal Crimpers - What do you use? #636698
03/11/10 02:15 PM
03/11/10 02:15 PM
United States
STLDuster Offline OP
United States
I am looking at upgradeing my wire crimpers. I have always used the cheap ones that came in a kit from the autoparts store.
This style:
What would you recomend for an upgrade?
"No great genius has ever existed without some touch of madness." - Aristotle
Re: Wire Terminal Crimpers - What do you use? [Re: STLDuster] #636699
03/11/10 02:42 PM
03/11/10 02:42 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
Mine looks pretty similar to that and works fine. I suppose there might be some really nice ones out there, but I never looked.
Scott
1969 Super Bee, 383/4 speed
Re: Wire Terminal Crimpers - What do you use? [Re: StukaJU87] #636700
03/11/10 04:38 PM
03/11/10 04:38 PM
Bucks County, PA
500Stroker Offline
500Stroker  Offline
Bucks County, PA
Re: Wire Terminal Crimpers - What do you use? [Re: 500Stroker] #636701
03/11/10 04:40 PM
03/11/10 04:40 PM
New Jersey, US of A
PlumCrazy73Dodge Offline
New Jersey, US of A
I agree with
TO crimp they are better and get a tighter crimp...the other style can still do your stripping and odds and ends
73 plumcrazy challenger - 318/904, edelbrock performer 600cfm carb, performer intake and cam. Eddy Alum. Heads 3.91 locker, Doug's headers, accurate ltd. exhaust
73 Cuda - Triple Black 340 4 speed
MIKE
Re: Wire Terminal Crimpers - What do you use? [Re: PlumCrazy73Dodge] #636702
03/11/10 05:10 PM
03/11/10 05:10 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
These work the best from my experience and I've tried them all in a lifetime of working in electronics. I can say from experience these work better then the blue handle ones in the pic as I've had both.
$20 is cheap too...
http://www.summitracing.com/parts/OTC-4497/
Re: Wire Terminal Crimpers - What do you use? [Re: Lefty] #636703
03/11/10 05:43 PM
03/11/10 05:43 PM
Champlin Mn.
2
2DoorPost Offline
2DoorPost  Offline
Champlin Mn.
I use a small vise grip
Re: Wire Terminal Crimpers - What do you use? [Re: Lefty] #636704
03/11/10 05:46 PM
03/11/10 05:46 PM
sg66mopar Offline
sg66mopar  Offline
$20 is cheap too...
Built and wired trailers for 26 years. These, or any similar decent quality substitute are by far the best.
Re: Wire Terminal Crimpers - What do you use? [Re: sg66mopar] #636705
03/11/10 05:52 PM
03/11/10 05:52 PM
scratchnfotraction Offline
I use a set of klien crimper...looks like the blue channel lock ones posted
Re: Wire Terminal Crimpers - What do you use? [Re: 500Stroker] #636706
03/11/10 05:59 PM
03/11/10 05:59 PM
United States
United States
I upgraded from those to this.
Hmmm... My Dad has a set of those in his tool box that I have been overlooking for years. To be honest I didn't know what they were.
Thanks for the tips, I am going to have to try out a set like those from Summit.
Re: Wire Terminal Crimpers - What do you use? [Re: scratchnfotraction] #636707
03/11/10 06:00 PM
03/11/10 06:00 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
It really depends on what type of terminals you are crimping. I recently got some factory-style terminals and went looking for a tool that would put a factory-style crimp on. That tool is not easy to find, but my boss had one at home...... Well, ok, it's not that they are hard to find, but they are expensive.
Re: Wire Terminal Crimpers - What do you use? [Re: Jim_Lusk] #636708
03/11/10 06:04 PM
03/11/10 06:04 PM
United States
United States
It really depends on what type of terminals you are crimping...
Something like these from Napa, Crimp-on not the solder-on (old picture)
Re: Wire Terminal Crimpers - What do you use? [Re: Jim_Lusk] #636709
03/11/10 06:06 PM
03/11/10 06:06 PM
Boise Idaho
Boise Chall Offline
Boise Chall  Offline
Boise Idaho
I remove the piece of plastic on the crimp area of the terminal slide a piece of shrink tube on the wire crimp the terminal with a set of panduit crimpers then solder the wire/terminal then slide the shrink tube over the crimp area of the terminal and shrink it this makes a perfectly conductive permanent connection
Re: Wire Terminal Crimpers - What do you use? [Re: STLDuster] #636710
03/11/10 06:12 PM
03/11/10 06:12 PM
Hangtowner Offline
Hangtowner  Offline
The crimper from Griot's Garage is from Germany and is quite fantastic and a pleasure to use.
Re: Wire Terminal Crimpers - What do you use? [Re: STLDuster] #636711
03/11/10 07:05 PM
03/11/10 07:05 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A good crimper for insulated terminals should crimp both the terminal and also crimp the strain relief portion behind it onto the wire insulation in one operation.
Re: Wire Terminal Crimpers - What do you use? [Re: John_Kunkel] #636712
03/11/10 07:08 PM
03/11/10 07:08 PM
Cen Fla
j3wbagell Offline
j3wbagell  Offline
Cen Fla
THese are hands down amazing "Ceramic tile nippers"
Re: Wire Terminal Crimpers - What do you use? [Re: John_Kunkel] #636713
03/11/10 07:31 PM
03/11/10 07:31 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Now when I see that type, and pic thats the crimper I want. There out there ,I think you can get them on Ebay for around $30 bus or so. mike
Re: Wire Terminal Crimpers - What do you use? [Re: Sport440] #636714
03/11/10 08:04 PM
03/11/10 08:04 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I finally broke down and bought a pair with the spring loaded fingers that allow you to strip the wire in the jaws by squeezing them closed.
It is a great tool for fixing wires under the dash or in a bad place because you only need one hand to strip off the insulation, instead of one hand to hold the pliers and the other to pull the wire thru....
Re: Wire Terminal Crimpers - What do you use? [Re: Jim_Lusk] #636715
03/11/10 09:43 PM
03/11/10 09:43 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
If you go to NAPA,they have the correct tool to crimp factory type terminals.Paid around $35.They also have the terminals.
Re: Wire Terminal Crimpers - What do you use? [Re: 62maxwgn] #636716
03/11/10 10:02 PM
03/11/10 10:02 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Sta-Kon brand is good if you cam find them. I have one I have used for 25+ years and still crimps and cuts like new. Long handles for extra leverage.
If you like drag racing, support your local track.
Re: Wire Terminal Crimpers - What do you use? [Re: 62maxwgn] #636717
03/11/10 11:18 PM
03/11/10 11:18 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The NAPA price on the terminals is excessive at best. I found them in similar quantities at a local supplier for less than 1/4 of NAPA's price.
