3.91 or 4.30 gears for the street and track? #635936
03/10/10 06:59 PM
03/10/10 06:59 PM
WI, USA
67dodge67 Offline OP
mopar addict
mopar addict
WI, USA
I've got a simple question here. 67 Coronet, 470, 727, 11" PTC converter, 28" tire. Which gears would you choose? 3.91 or 4.30? It will see both street and strip.
Opinions?
Thanks for your help.
Re: 3.91 or 4.30 gears for the street and track? [Re: 67dodge67] #635937
03/10/10 07:00 PM
03/10/10 07:00 PM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
3.91's would be my choice
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: 3.91 or 4.30 gears for the street and track? [Re: 67dodge67] #635938
03/10/10 07:01 PM
03/10/10 07:01 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
With 4.30's and a 28" tire, you may run out of rpm before the end fo the 1/4 mile. And niether one of those gears will be the greatest on the highway but you can play with this calculator:
http://vexer.com/68rt/speed.html
Re: 3.91 or 4.30 gears for the street and track? [Re: mopars_1] #635939
03/10/10 07:04 PM
03/10/10 07:04 PM
upstate, New York
jvcuda Offline
jvcuda  Offline
upstate, New York
Have a 3.91 in my '73 cuda,440,727,28" tire
Re: 3.91 or 4.30 gears for the street and track? [Re: DaytonaTurbo] #635940
03/10/10 07:05 PM
03/10/10 07:05 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
3:91's. There not that bad on highway. 4:30's are way to much. Top speed on high way will be around 60 and taching around 3800 to 4000. I had 4:57's with a 4 speed. It was fun around town but forget the high way a prius will blow your doors off on the freeway. lol
Re: 3.91 or 4.30 gears for the street and track? [Re: Dougsmopars] #635941
03/10/10 07:11 PM
03/10/10 07:11 PM
New Zealand
solidcam Offline
solidcam  Offline
New Zealand
Re: 3.91 or 4.30 gears for the street and track? [Re: Dougsmopars] #635942
03/10/10 07:14 PM
03/10/10 07:14 PM
N.E. Ohio
K
KillerBee Online content
KillerBee  Online Content
K
N.E. Ohio
Between the 3.91 and the 4.30 I would pick the 3.91's unless you want evey tenth in the 1/4 but the 4.30 gear might be too much gear with a 28" tire.
If I had my choice I would go with 4.10, that's what I have in my Challenger with 28" tall tires.
Re: 3.91 or 4.30 gears for the street and track? [Re: KillerBee] #635943
03/10/10 07:23 PM
03/10/10 07:23 PM
WI, USA
mopar addict
mopar addict
WI, USA
Ok. So far it seems 3.91's are the better bet here. Thanks for the input!
By the way, nice Challenger!
Re: 3.91 or 4.30 gears for the street and track? [Re: 67dodge67] #635944
03/10/10 08:41 PM
03/10/10 08:41 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I did a 3.73 w/a 470" and a 4 spd in my 69 B'cuda w/a 26" tire. With your 28" tire I think the 3.91's will be a good fit for street/strip!!
Re: 3.91 or 4.30 gears for the street and track? [Re: Dcuda69] #635945
03/10/10 10:29 PM
03/10/10 10:29 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
i have 4.30's wit ha 28" tire, 10" converter. i love it. around town its a blast. i drive 60 miles to the track but i keep it at 60 mph. 65 max. at 60 mph im revving around 3300 rpm, at 65 around 3500 rpms
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
Re: 3.91 or 4.30 gears for the street and track? [Re: aarcuda] #635946
03/10/10 10:36 PM
03/10/10 10:36 PM
WI, USA
mopar addict
mopar addict
WI, USA
Hmmm.... interesting.... I haven't committed to either gear set as of yet... a 10" converter makes a difference then... anyone else with a similar set up as well?
Thanks!
Re: 3.91 or 4.30 gears for the street and track? [Re: 67dodge67] #635947
03/10/10 10:46 PM
03/10/10 10:46 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
a 28 inch tire may rub the wheel well. I put 29's on mine and the fit but rubbed on a bump so out they came. I would say 27's would work and the 391's would be fine...430's may be too much for the motor...what HP ?
Re: 3.91 or 4.30 gears for the street and track? [Re: terzmo] #635948
03/10/10 10:57 PM
03/10/10 10:57 PM
Willoughby Hills, Ohio
gd9704 Offline
super gas
gd9704  Offline
super gas
I run 3.91s....I would consider them "max" if you're going to do any freeway driving....
Re: 3.91 or 4.30 gears for the street and track? [Re: gd9704] #635949
03/10/10 11:39 PM
03/10/10 11:39 PM
CT USA
N
Nick Mineau Offline
Nick Mineau  Offline
N
CT USA
i vote 3.91 but 3.55 would be better if you plan on driving it a bunch. a 440 should have plentey of power even with 2.73"S LOL. you might loose .2 in the 1/4 but it will go down the road much better. it really sucks when your race car cant keep up with traffic
Re: 3.91 or 4.30 gears for the street and track? [Re: 67dodge67] #635950
03/11/10 08:46 AM
03/11/10 08:46 AM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
Thanks!
Same set up here but with a 340. I instaled a 416 last year and with the added torque I'm thinking of switching to a 3.91.
How tight do you want to turn that 470?
The 4.30 is fun stop lite to stop lite and if your not in hurry Ok on the freeway but I think the 3.91 will be more liveable.
Re: 3.91 or 4.30 gears for the street and track? [Re: jvcuda] #635951
03/11/10 11:48 AM
03/11/10 11:48 AM
Berwyn, IL
challenger70 Offline
Berwyn, IL
Same combo I have in my challenger, fun on the streets and ok on the highway below 70.
Re: 3.91 or 4.30 gears for the street and track? [Re: challenger70] #635952
03/11/10 12:35 PM
03/11/10 12:35 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I had a Challenger with 29" tall rears and 4:10s. I did not like to drive on the highway. Too many RPMs to go 60mph.
Keep old mopars alive.
Re: 3.91 or 4.30 gears for the street and track? [Re: 2boltmain] #635953
03/11/10 01:04 PM
03/11/10 01:04 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
I have 29 inch tires on My bee with a 4 speed and turn just a hair less than 65 at 3000 rpm. 440 and 410 dana
The stock wheel well on 66 and 67 coronet and satellites don't accept a real big tire. I've seen 275 width the most with special offset wheels. BUT...try and fix a flat on the road with them. The wheel well on a 68 on up will accept much bigger tires/wheels.
Re: 3.91 or 4.30 gears for the street and track? [Re: terzmo] #635954
03/11/10 01:56 PM
03/11/10 01:56 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
Surprised several years ago a buddy talked me into replacing my 3.91's with 3.23's. Ran 12.20's and 112 w/3.91's and 12.40's at 111 w/3.23's. Mileage went from 9 to 13 one the road, 65mph. Motor makes 511hp 580tq 500in...it doesn't care much for a deep gear. Torque motor.
The little old lady from Pasadena is back!
Re: 3.91 or 4.30 gears for the street and track? [Re: terzmo] #635955
03/11/10 02:11 PM
03/11/10 02:11 PM
WI, USA
mopar addict
mopar addict
WI, USA
Going with the 3.91's. I mini tubbed my car a while back so I have added room for tires. Before I did that, I was able to get 255x70x15's in it but wanted a wider tire so I now have 275x60x15 mt drag radials.
Now I'm wondering which converter to use... I have an 11" now, but thinking a 10" or maybe a 9.5" would be better.
Thanks again for all the input.
