Can you buy a single R9357-35 top ring and second ring? #635805
03/10/10 05:16 PM
03/10/10 05:16 PM
IN
Irun5snd8th Offline OP
IN
I have a set of 7 and just need the kit for one piston and trying to avoid buying a $150 set of rings when I only need 1 hole. Can't find a phone number for Speed Pro.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Can you buy a single R9357-35 top ring and second r [Re: Irun5snd8th] #635806
03/10/10 05:38 PM
03/10/10 05:38 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I bent one of my total seal rings and called and was able to buy rings for one piston.
Re: Can you buy a single R9357-35 top ring and second r [Re: 69Cuda340S] #635807
03/10/10 06:08 PM
03/10/10 06:08 PM
gregsdart Offline
gregsdart  Offline
I messed on up , and Childs and Albert sent me another, no charge.
Re: Can you buy a single R9357-35 top ring and second ring? [Re: Irun5snd8th] #635808
03/10/10 09:16 PM
03/10/10 09:16 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Speed Pro is a pain to get single rings from. They want to sell you a complete set of rings ( IE: 8 top rings, 8 second rings etc ) and that is if your lucky to deal with someone that actually wants to help.I can give you the individual rings part numbers, but I dont think its going to help you much.
Total Seal will help as will Hastings. Where your located goegraphically, just call Hastings, ask for tech, and they will hook you up with a single ring.
RIP Monte Smith
Re: Can you buy a single R9357-35 top ring and second ring? [Re: CompWedgeEngines] #635809
03/10/10 10:22 PM
03/10/10 10:22 PM
IN
IN
I will call Hastings. I don't feel like paying 155 for another set when all I need is two rings. Thanks for the info!
Re: Can you buy a single R9357-35 top ring and second ring? [Re: Irun5snd8th] #635810
03/10/10 11:25 PM
03/10/10 11:25 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
Total Seal was AWESOME resently when I needed something from them. The Guy flat out knew his stuff and gave me exactly what I needed.
SRT DEMON ONE SEAT
Re: Can you buy a single R9357-35 top ring and second ring? [Re: Irun5snd8th] #635811
03/10/10 11:30 PM
03/10/10 11:30 PM
Alberta, Can
JUST_N_TIME Offline
JUST_N_TIME  Offline
Alberta, Can
I bought a single set from Diamond Pistons a couple years back.
Re: Can you buy a single R9357-35 top ring and second ring? [Re: Ron Silva] #635812
03/10/10 11:31 PM
03/10/10 11:31 PM
Syracuse,NY
Syracuse,NY
Yes, Total Seal is great to deal with as well. Keith knows his business. Just figured he is closer to Michigan, so may save him and extra day.
RIP Monte Smith
Re: Can you buy a single R9357-35 top ring and second ring? [Re: JUST_N_TIME] #635813
03/10/10 11:33 PM
03/10/10 11:33 PM
Syracuse,NY
Syracuse,NY
Diamond doesnt really deal in the loose stock anymore. They used to buy from Mahle, and buy open stock, but that has kind of dissolved. Mostly boxed sets now from Total Seal.
RIP Monte Smith
