Re: Anyone else ever over charge their Ultima battery?
[Re: dc426]
#635776
03/10/10 03:49 PM
03/10/10 03:49 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Very dangerous, hydrogen gas, if you would have tried to unhook the battery charger ends in the trunk with the contained gas..... You avoided a very bad accident...
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#635777
03/10/10 04:42 PM
03/10/10 04:42 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Dang, i have never heard of that.
glad your OK
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#635778
03/10/10 04:46 PM
03/10/10 04:46 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
i did it too.. i smelled somthing terrible and as i got closer realised i had turned the dial on the charger to the hold... it fried the batt...the case was swelled.. really hate it ....cause that sucker was one of the last of the good ones...i couldnt kill it before this... the 2 new ones since ...bite it hard....fwiw. cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: rickstershemi]
#635783
03/11/10 11:02 AM
03/11/10 11:02 AM
Posts: 6,314 The Swamp
MegaDart
The Swamp
I bought one of the "SMART" chargers and even if you set it at 20 amps it will automatically lower the amperage as necessary
After running a "Dry Cell" battery I will never run a wet cell again....the "Odyssey" batteries are all I will ever buy from now on, even replacements for our daily drivers
Rickster
or until you try a 16volt!!
[Re: dc426]
#635784
03/11/10 11:35 AM
03/11/10 11:35 AM
Posts: 876 Arizona
PolyDart
Arizona
Has this happened to anyone else?
I've seen it happen on a Ford Explorer with an Optima. We thought the truck was overheating from the "steam" that was coming from under the hood. Opened the hood and saw the "volcano" you described shooting out of one of the battery vents.
We tested the alternator output right there once it stopped fuming and the voltage was less than 14.
Optima blamed the problem on the alternator and wouldn't replace the battery even though it was still under warranty
