8-3/4 rear end question #635456
03/10/10 12:37 AM
03/10/10 12:37 AM
North Central Florida
E
eightlitermopar Offline OP
E
So I just picked up a one legger rear end (489 case) so I need to put a sure-grip unit in it.
Now as I am looking around doing research, there are so many different kinds.
TrueTrac helicial gear
power-lock
etc.
So what are the pros and cons of all of these? My car will not be a 1/4 mile king, mild 440 for cruising and some back road burnouts.
Which one would be better, last longer, be stronger, etc.
I am learning alot here
any thoughts?
eight
Mopar or no car
Re: 8-3/4 rear end question [Re: eightlitermopar] #635457
03/10/10 12:52 AM
03/10/10 12:52 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Power Loc is a discontinued Dana product and is generally considered the best for racing applications and a great street piece.
The other factory option is a suregrip (based on the borg warner antispin design) and is also a good piece but not as good for all out..
There are a few aftermarket options like the tru trax based on a new design that locks some teeth together and should work OK, and the
Auburn which is a newer version of the Borg Warner antispin design...
