Hi
I'm hoping to find the experts on EL here...
I'm trying to get a friend's EL dash to light. He said it was "working" but the speedometer had grounding issues.
All I have is the dash and a transformer ("oscillator). The transformer has a two lead "T" shaped connector hanging off it with white and orange wires. The schematic shows power coming in on the white wire and outputs on the orange which connects to a white wire on the dash. I assume there's a case ground for the dash and transformer.
I'm trying to do some bench testing and wanted to verify I've got the in/out right before I apply power.
Any additional guidance would also be greatly appreciated.
